23 Pages«<7891011>»
Online uni
#161 Posted : 02 June 2013 07:01:21(UTC)
uni
Updated. Animation added.
Edited by user 02 June 2013 07:03:28(UTC)  | Reason: Not specified
File Attachment(s):
MaplePlot. Example of animation 1.pdf (47kb) downloaded 70 time(s).
MaplePlot. Example of animation 1.gif (610kb) downloaded 50 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 02/06/2013(UTC)
Offline omorr
#162 Posted : 02 June 2013 08:57:14(UTC)
omorr
Serbia
Good work uni Good
I've noted the "Export" button was added (maybe it was here but I missed it). This can be used to save the plot in the GIF format, animated or not, like the SMath's base plots.
I suppose copying the plots from one worksheet to another will be fixed as well as soon as the plot saving fix will work.
Offline sija
#163 Posted : 02 June 2013 10:27:53(UTC)
sija
Poland
Viacheslav,
Thank you for the new version of MapleWrapper plugin. This is really impressive to have so beautiful tool like your plugin in SMath Studio. Once again thank you heartily.
Janusz
Offline sija
#164 Posted : 02 June 2013 13:42:13(UTC)
sija
Poland
I know how to dissolve one differential equation of the any degree using MapleWrapper plugin. But how to dissolve the system of ODE using MapleWrapper, this unfortunately I do not know. Please for the help.
I tried in different ways to reach the result, however ineffective.Sad
From above heartily thank you for your help.
Janusz
Offline omorr
#165 Posted : 02 June 2013 22:38:15(UTC)
omorr
Serbia
Janusz
I am not quite sure this was correctly solved using Maple
Edited by user 03 June 2013 00:03:23(UTC)  | Reason: Not specified
File Attachment(s):
odesystem.sm (10kb) downloaded 51 time(s).
Offline sija
#166 Posted : 03 June 2013 15:16:08(UTC)
sija
Poland
Hello Radovan,
Thank you for these examples. I think that I know already where I made mistakes. Thank you also for your kind - already several times you helped me.
Janusz
Offline omorr
#167 Posted : 03 June 2013 16:31:47(UTC)
omorr
Serbia
You are welcome Janusz Good
And do not hesitate to ask, as I always do
Offline sija
#168 Posted : 04 June 2013 19:02:24(UTC)
sija
Poland
Make calculations in MapleWrapper must be record the tangent function as: "tan" what it is visible on the first picture. To closing of the file and his repeated opening SMath Studio changes the function tanges from the record: "tan" - required through MapleWrapper, on "tg", and in the this moment MapleWrapper cannot make calculations because it has implemented the tangent function as "tan" and not "tg" as in SMath Studio in the this moment - look the second picture. Well would be to standardize this mark of the tangent function in MapleWrapper and SMath Studio.
Janusz
Before save:
Before save
After open:
After open
Online uni
#169 Posted : 04 June 2013 19:16:39(UTC)
uni
I think this is a bug (Smath Studio, not mine). The same works and for cot(). You can define the function tg():=tan() and it should work.
The names of the trigonometric functions depends on the settings of the program. I consider them.
Edited by user 04 June 2013 19:22:07(UTC)  | Reason: Not specified
Russia ☭ forever
Offline sija
#170 Posted : 04 June 2013 19:25:54(UTC)
sija
Poland
Hello Uni,
Thank you for explanations and the council.
Janusz
Online uni
#171 Posted : 04 June 2013 20:00:28(UTC)
uni
There still need to add that maple() function doesn't support nested expressions fully. I had not planned to use such complex commands.
uni attached the following image(s):
Russia ☭ forever
Offline sija
#172 Posted : 04 June 2013 20:37:21(UTC)
sija
Poland
Viacheslav,
This is very instructive and surprising Good example. My congratulations! Thank you very much!
Janusz
Offline sija
#173 Posted : 06 June 2013 20:19:28(UTC)
sija
Poland
Hello!
Please for the explanation why I receive two different results as this is visible on the example below:
Where is the error?
Janusz
File Attachment(s):
Where is the error.sm (8kb) downloaded 40 time(s).
Online uni
#174 Posted : 06 June 2013 20:45:19(UTC)
uni
There is no error. This behavior depends on the relative positions of the expressions on the sheet. When you put the definition of x above of a function call, the variable x in the expression solver becomes zero.
Russia ☭ forever
Offline sija
#175 Posted : 06 June 2013 20:54:16(UTC)
sija
Poland
Hello Uni,
Thank you for the explanation. The first time I meet with such by chance.
Janusz
Offline sija
#176 Posted : 06 June 2013 21:20:16(UTC)
sija
Poland
Uni,
I cannot obtain such result as you. Can I ask you for the source file of your results.
Janusz
Offline omorr
#177 Posted : 06 June 2013 21:32:29(UTC)
omorr
Serbia
I Installed MapleWrapper from the Online Gallery Good
It seems Maple is working fine, but, unfortunately, MaplePlot can not produce a plot for me. There are still "empty" plots there, in spite of inserting the plotting text inside them Sad .
I hope I did not do something wrong.
Edited by user 06 June 2013 21:37:31(UTC)  | Reason: Not specified
File Attachment(s):
mvr5.txt (9kb) downloaded 30 time(s).
Online uni
#178 Posted : 06 June 2013 21:46:01(UTC)
uni
Not so fast Good There's a bug. This is a test version for the new version SMath Studio. I'll combine Maple and MaplePlot regions.
Russia ☭ forever
on 06/06/2013(UTC)
Offline sija
#179 Posted : 07 June 2013 18:32:03(UTC)
sija
Poland
Right now I noticed, that the power in the calculation of the value t (0) at the end of your sheet is positive. From here the conclusion: there is the error because the value t(0) have to be zero. The value x equal zero is given at the end because here I pass to numerical calculations.
If I am wrong please for the explanation.
Janusz
Edited by user 07 June 2013 19:48:19(UTC)  | Reason: Not specified
Online uni
#180 Posted : 07 June 2013 20:13:56(UTC)
uni
When you are trying to calculate the last expression the maple() function takes the following expression (see mvr5\mvr5.txt):
As you can see: solve({(0=, but you expected solve({(x=. That's the difference. The solve() function solves another equation.
Russia ☭ forever
23 Pages«<7891011>»
