24 Pages«<678910>»
Offline omorr
#141 Posted : 27 May 2013 14:21:55(UTC)
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
Nice the shading thing Good
By the way, I could see that some internal SMath constants could not be used in maple - see the picture.
Not so important at the moment, I am just curious
on 27/05/2013(UTC)
Offline omorr
#142 Posted : 27 May 2013 14:28:20(UTC)
omorr
Serbia
I just excuse myself, If this was already mentioned before.
I could see that the Maple Wraper plugin is listed three times in the plugin list. Why is this?
And, I did not notice "Maple" option in the menu before (besides "Maple Plot" ). What is it for? I tried it and it just crushed SMath
Offline uni
#143 Posted : 27 May 2013 14:59:47(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Updated. This is an experimental thing for scripting support.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 27/05/2013(UTC)
Offline sija
#144 Posted : 27 May 2013 20:13:05(UTC)
sija
Poland
Viacheslav,
I like to thank you for the immensity of the work which you put into the creation of this beautiful plugin. Thank you for the new version of MapleWrapper plugin.
Janusz
Edited by user 27 May 2013 20:20:04(UTC)  | Reason: Not specified
thanks 1 user thanked sija for this useful post.
on 28/05/2013(UTC)
Offline sija
#145 Posted : 27 May 2013 20:17:44(UTC)
sija
Poland
I have also the same problem in SMath Studio.
Janusz
Offline mkraska
#146 Posted : 27 May 2013 22:43:30(UTC)
mkraska
Uni, as I understand, the save problem arises, when a plugin offers a region and a function. Could splitting the dll be a temporary workaround? Or replicating with different names?
I attach a version of the mapleplot examples with screenshots included, thus one can see what was meant to be the result (and the placeholder input).
EDIT: Example 7 now included.
Edited by user 29 May 2013 16:17:23(UTC)  | Reason: Not specified
File Attachment(s):
Mapleplot_Examples.zip (72kb) downloaded 84 time(s).
on 27/05/2013(UTC),  on 28/05/2013(UTC)
Offline uni
#147 Posted : 28 May 2013 01:51:57(UTC)
uni
This is normal when the plugin consists three objects:
1) set of functions;
2) Maple Plot Region (with placeholder);
3) Maple Region (without placeholder).
Yes it could but I think Andrey will fix it as soon as possible.
Quote:
For example 7 I didn't guess, therefore you might add that.
on 29/05/2013(UTC)
Offline uni
#148 Posted : 31 May 2013 17:18:18(UTC)
uni
Updated (maple()). Fixed issue with trigonometric functions, added support for units.
Edited by user 31 May 2013 17:21:59(UTC)  | Reason: Not specified
on 31/05/2013(UTC)
Offline sija
#149 Posted : 31 May 2013 17:37:36(UTC)
sija
Poland
Viacheslav,
Janusz
on 31/05/2013(UTC)
Offline uni
#150 Posted : 01 June 2013 09:53:00(UTC)
uni
Updated. Little improvements.
a := plot(`in`, x=0..2*Pi, coords=polar,
scaling=constrained, style=line, color=blue, axes=normal):
b := coordplot(polar,[0..3/2,0..2*Pi],labelling=false,
linestyle=[7,4], color=[gray,gray]):
display([a,b]);
on 01/06/2013(UTC)
Offline sija
#151 Posted : 01 June 2013 10:50:38(UTC)
sija
Poland
Viacheslav,
Thank you again for the new version of MapleWrapper plugin. Perfect work.
Janusz
on 01/06/2013(UTC)
Offline omorr
#152 Posted : 01 June 2013 14:02:36(UTC)
omorr
Serbia
Hello uni,
I've just tried your test files and noted errors only on Test6 file. This is the PDF (left) and SMath file(right) on my computer.
EDIT: I forgot mvr5.txt file, sorry
Edited by user 01 June 2013 16:39:45(UTC)  | Reason: Not specified
File Attachment(s):
mvr5.txt (19kb) downloaded 42 time(s).
on 01/06/2013(UTC)
Offline sija
#153 Posted : 01 June 2013 16:13:12(UTC)
sija
Poland
Hello Uni and Radovan,
I tested files: maple.Test 1, maple.Test 2, maple.Test 3, maple.Test 4, maple.Test 5 and maple.Test 6 on my computer. All is OK.
Janusz
on 01/06/2013(UTC)
Offline uni
#154 Posted : 01 June 2013 16:27:40(UTC)
uni
Janusz
This test is to verify the work with trigonometric functions. Its operation depends on the settings of the program. The current version has a few bugs, I will fix them.
on 01/06/2013(UTC)
Offline omorr
#155 Posted : 01 June 2013 20:00:01(UTC)
omorr
Serbia
Is there any way that MapleWrapper could work in Linux? Is there any sense about that? That would be quite interesting Good
I tried it but it does not work or an error in the maple() region appear:
"File not found: /home/omorr/Downloads/SMathStudioDesktop.0_96_4884.Mono\plugins\mvr5\cmaple.exe"
MaplePlot will just close SMath
Offline uni
#156 Posted : 01 June 2013 20:22:31(UTC)
uni
I can say nothing about it. At the moment there is no way to check.
In the next version I will add animation.
uni attached the following image(s):
on 01/06/2013(UTC),  on 01/06/2013(UTC)
Offline sija
#157 Posted : 01 June 2013 23:10:30(UTC)
sija
Poland
I like to dissolve the differential equation with initial conditions with MapleWrapper plugin. Is it possible? How to do it. Please fo some help.
In Maple V the required syntax is like below:
dsolve({ODE, ICs}, y(x))
Parameters:
ODE - an ordinary differential equation
y(x) - the dependent variable (indeterminate function)
ICs - initial conditions for y(x) and/or its derivatives
but in SMath Studio I can not introduce the following parenthesis: {}
Janusz
Offline mkraska
#158 Posted : 01 June 2013 23:26:30(UTC)
mkraska
That has been explained here
Offline omorr
#159 Posted : 01 June 2013 23:26:37(UTC)
omorr
Serbia
Parameters:
Janusz
Uni explained that here
By using convert() the Maple set {} was obtained from SMath system { .
Edited by user 01 June 2013 23:28:42(UTC)  | Reason: Not specified
Offline sija
#160 Posted : 02 June 2013 00:26:09(UTC)
sija
Poland
Hello Radovan,
Thank you for your help. The "convert" is a really magical word. Once again thank you heartily.
Janusz
Guest (2)
24 Pages«<678910>»
