23 Pages«<56789>»
Offline omorr
#121 Posted : 25 May 2013 00:33:52(UTC)
omorr
Serbia
First and second order ODE examples.
I do not know how to solve them in one step like. How to put sets - {} in the command?
>dsolve({D(y)(x)=x-y,y(0)=1},y(x))
Could someone give some help?
File Attachment(s):
ode1.sm (10kb) downloaded 61 time(s).
ode2.sm (14kb) downloaded 60 time(s).
Offline uni
#122 Posted : 25 May 2013 02:54:08(UTC)
uni
Was thanked: 1382 time(s) in 806 post(s)
Updated. The document can not be saved. I don't know why.
plot([`in`[1], `in`[2], t=0..2*Pi], color=blue );
plot3d( `in`, x=-5..5, y=-5..5, scaling=constrained, style=patch,
orientation=[40,50], grid=[50,50], color=gray, axes=frame,
lightmodel=`light4`, projection=`normal`, shading=zgrayscale );
implicitplot3d( `in`=0, x=-2..2, y=-2..2, z=-2..2, grid=[50,50,50], orientation=[20,60],
axes=frame, lightmodel=`light4`, projection=`normal`, style=patchnogrid);
F:=implicitplot3d( `in`[1]=0, x=-2..2, y=-2..2, z=-2..2, grid=[30,30,30],
style=patchnogrid ):
G:=plot3d(`in`[2], x=-2..2, y=-2..2, style=patch, color=white):
display({F,G}, orientation=[20,60], axes=box, lightmodel=`light2`,
projection=`normal`, labels=["X","Y","Z"], scaling=constrained,
tickmarks=[4,4,4] );
f(x;y;z)Sada^2*(x^2+y^2+z^2))^{-2}+(b^8*(x^8+y^8+z^8))^4-2
F:=implicitplot3d( `in`=0, x=-2.1..2.1, y=-2.1..2.1, z=-2.1..2.1,
grid=[50,50,50], style=patchnogrid ):
display({F}, orientation=[35,55], axes=box, lightmodel=`light4`,
Edited by user 25 May 2013 08:22:58(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
Offline uni
#123 Posted : 25 May 2013 10:50:17(UTC)
uni
Edited by user 25 May 2013 11:53:03(UTC)  | Reason: Not specified
Offline omorr
#124 Posted : 25 May 2013 12:52:17(UTC)
omorr
Serbia
Aha,...convert() was the magic word. Thank you Good
Strange, but this one was the only one successful
My other attempts in making plots and reproducing your pictures, issued an error about missing gif file in tmp folder. See the picture please
The problem of not saving pictures and SMat crash still remained.
Offline uni
#125 Posted : 25 May 2013 13:08:25(UTC)
uni
Show me the log file: mvr5.txt.
Offline omorr
#126 Posted : 25 May 2013 13:19:05(UTC)
omorr
Serbia
Here it is. If you want me something in particular to try, just let me know.
File Attachment(s):
mvr5.txt (193kb) downloaded 43 time(s).
Offline omorr
#127 Posted : 25 May 2013 13:40:59(UTC)
omorr
Serbia
This one is after deleting mvr5.txt and trying to make a parametric 3dplot
Edited by user 25 May 2013 13:42:45(UTC)  | Reason: Not specified
File Attachment(s):
mvr5.txt (3kb) downloaded 37 time(s).
Offline uni
#128 Posted : 25 May 2013 13:59:09(UTC)
uni
Radovan, you have to change the maple-commands for each graph. In your example these commands are set incorrectly. I specifically show the commands. They need to be inserted into the settings form, as showed above.
1) Try this:
a := plot( `in`, t=0..20, x=-1.5..1.5, scaling=unconstrained, style=line,
color=blue, axes=box, labels=["t","x(t) "]):
b := coordplot(rectangular, [0..20, -1.5..1.5], linestyle=[7,7],
color=[gray,gray]):
display([a,b]);
2) projection=`normal must be projection=`normal`
Edited by user 25 May 2013 14:11:28(UTC)  | Reason: Not specified
Offline omorr
#129 Posted : 25 May 2013 15:04:10(UTC)
omorr
Serbia
I tried your suggestion (just copy/paste) and calculation take quite long (did not wait for it to finish). Just used the simple one, and it worked (the first picture). It is good enough for me Good .
Tried one of your examples, and typed carefully as much as I could. I did not see any mistake - but the plot did not appear (the second picture) Sad
Edited by user 25 May 2013 15:07:03(UTC)  | Reason: Not specified
File Attachment(s):
mvr5.txt (266kb) downloaded 32 time(s).
Offline uni
#130 Posted : 25 May 2013 15:14:41(UTC)
uni
Try to add with(plots): to with.inc:
Quote:
with(linalg):with(inttrans):with(plots):
Offline omorr
#131 Posted : 25 May 2013 15:26:25(UTC)
omorr
Serbia
It worked Good . What was the catch?
Offline omorr
#132 Posted : 25 May 2013 19:26:54(UTC)
omorr
Serbia
Nice Good
File Attachment(s):
ode2-boundary.sm (19kb) downloaded 70 time(s).
on 26/05/2013(UTC)
Offline uni
#133 Posted : 26 May 2013 02:40:31(UTC)
uni
MaplePlot updated. Small imprоvements.
on 26/05/2013(UTC)
Offline omorr
#134 Posted : 26 May 2013 09:59:31(UTC)
omorr
Serbia
Just to confirm. The EMPTY PLOT is now working fine. No crash of SMath at the plot inserting Good
Offline sija
#135 Posted : 26 May 2013 11:20:20(UTC)
sija
Poland
Heartily please for the prompt, how to check in Maple that two expressions are to themselves equal. For example whether the expression under variable a is such alone as the expression under variable b?
Janusz
Offline omorr
#136 Posted : 26 May 2013 13:26:32(UTC)
omorr
Serbia
I do not use maple to much (it is interesting and a fun using it in SMathGood ) , and someone else might give you a better solution - but this should work
e1Sada^2-1)*1/sqrt(a)
e2Sadb-1)*(b+1)/sqrt(Cool
maple(simplify(subs(a≡b,e1)-e2))=0
Radoavn
Offline sija
#137 Posted : 26 May 2013 14:32:54(UTC)
sija
Poland
Hi Radoavn,
Thank you, interesting solution, will try out it.
Janusz
Offline uni
#138 Posted : 27 May 2013 08:10:51(UTC)
uni
Updated. Still can't save region.
File Attachment(s):
MaplePlot. Example 8.sm (5kb) downloaded 78 time(s).
on 27/05/2013(UTC)
Offline mkraska
#139 Posted : 27 May 2013 09:22:01(UTC)
mkraska
Was thanked: 1167 time(s) in 746 post(s)
Thanks for the update.
I have still trouble with the basics. Example 2 does not work.
Here is what the log file says:
There are empty tmp files in the tmp dir:
tmp59BF.tmp
tmp5A0F.tmp
Offline uni
#140 Posted : 27 May 2013 10:07:10(UTC)
uni
In your example:
`in`Sadx^2+y^2+z^2)-1
but expected:
sys(el(`in`;1);el(`in`;2);2;1):sys((x^2+y^2+z^2)-1;0;2;1)
we get: `in`[1]="" , `in`[2]="" - empty values (because it is not a system) and `in`=(x^2+y^2+z^2)-1 (but is missing in script)
Must be:
tmp59BF.tmp
tmp5A0F.tmp
This is normal.
Edited by user 27 May 2013 10:11:12(UTC)  | Reason: Not specified
on 27/05/2013(UTC)
23 Pages«<56789>»
