23 Pages«<45678>»
Offline uni
#101 Posted : 05 May 2013 00:38:36(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Updated.
Maple doesn't support the expression of a subscript in the form of text. So you can't use such an expression. Dot (comma) between the identifier and other identifier (or number) is ignored. It reminds me a Lisp.
Russia ☭ forever
Viacheslav N. Mezentsev
Online mkraska
#102 Posted : 05 May 2013 00:59:57(UTC)
mkraska
Was thanked: 1131 time(s) in 726 post(s)
Perhaps an option to support text indices is to change the dot to underscore and vice versa in the interface. Maple can handle that, it the way it is done in latex and in SMath there is no reason for ugly variable names with underscores (except for compatibility with Mathcad Wink ) If variables with underscores are esential, then replace the dot by two underscores or something else that hardly is expected to be used.
However, I have no idea, how essential that is for the users and if that is easy to do in the current interface concept. In general, I appreciate the plugins supporting the base features of SMath. OK, I am not expecting unit support to come soon...
Offline uni
#103 Posted : 05 May 2013 14:04:40(UTC)
uni
Updated. I think I found a way. As for the units, I do not understand what you mean.
Russia ☭ forever
on 05/05/2013(UTC)
Online mkraska
#104 Posted : 05 May 2013 14:46:20(UTC)
mkraska
Again, great work, lots of thanks!
Now аll errors (mainly with parse and map) have gone.
The method for text indices that you found seems to be stable and cannot be tricked by numbers.
maple(diff((x.1^3+x.2^3),x.1))=3*x.1^2@#
However, same procedure...
I found another localization issue. When function style is set to european, that makes trouble. I think it would be sensible if internally there was always the same representation, regardless of local settings. Then the plugin providers would not be forced to handle that on their own and could focus on the added features. However, it is as it is.
maple(series(sh(x),x)) results in "empty stack"
As for the units: for purely symbolical calculations that is not required. This is more of an issue for numeric procedures like definite integration, ode and equations solving. These work in SMath only for unit-free integration variable or unknown variable. An example for better unit handling is the NonLinearSolvers plugin. You can specify initial values or limits with units and get results with units at the price of that you have to think about the dimensions of error tolerances.
Offline uni
#105 Posted : 05 May 2013 18:13:07(UTC)
uni
Updated. Added support for trigonometric functions.
It is should be done so:
uni attached the following image(s):
Russia ☭ forever
Online mkraska
#106 Posted : 05 May 2013 21:05:28(UTC)
mkraska
Thanks again for the update. Your examples work.
I've made a scanner for the series expansion example. It is, however, not entirely equivalent to direct non-optimized maple calls. What it can show, however, is that the function style settings sometimes work with "world" and sometimes with "europe" (the latter with arcsin, arccos). Perhaps maple names are a mix of both. Anyways, the scanner is demo for the power of the maplewrapper plugin combined with animation.
Edited by user 05 May 2013 21:10:04(UTC)  | Reason: Not specified
File Attachment(s):
Seriestest.sm (10kb) downloaded 63 time(s).
Offline uni
#107 Posted : 05 May 2013 21:36:27(UTC)
uni
Maple names. They will always work (in maple()), but the result will depend on the settings of the program. We need to use a Help to both programs to achieve adequate results.
Russia ☭ forever
on 05/05/2013(UTC),  on 05/05/2013(UTC)
Offline kaka
#108 Posted : 15 May 2013 02:47:56(UTC)
kaka
Rank: Member
Hi uni,
the expand function doesn't work
expand((x+1)*(x-1));
should be x^2-1 as in maple dos
but in SMath maple it gives me (-1+x)*(1+x)
could you have a look, thank you.
thanks 1 user thanked kaka for this useful post.
on 15/05/2013(UTC)
Offline uni
#109 Posted : 15 May 2013 03:02:51(UTC)
uni
Originally Posted by: kaka Go to Quoted Post
Hi uni,
Updated. Fixed. It seems that there is an internal function expand().
Edited by user 15 May 2013 03:05:03(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#110 Posted : 24 May 2013 08:34:13(UTC)
uni
Updated. Added experimental option to display 3D graphs (Maple Plot in the Insert list items).
Edited by user 24 May 2013 09:20:04(UTC)  | Reason: Not specified
Russia ☭ forever
Offline omorr
#111 Posted : 24 May 2013 10:23:43(UTC)
omorr
Serbia
I could not read your MaplePlot.Example-1.sm. Nothing appeared
I could get the plots by myself Good . The slight inconvenience is that as soon as I choose the Insert|Maple Plot I must insert something into the plot placeholder. If I just click outside the empty plot, SMath crashes (Win7(64))
Offline sija
#112 Posted : 24 May 2013 17:43:41(UTC)
sija
Poland
Hi Uni!
Thank you for the splendid MapleWrapper plugin. It is particularly useful because SMath Studio does not have yet it's own engine to symbolic calculations. Thank you once again.
However I have a small problem which I cannot dissolve. Below there are two images. First pictures is the situation before the record of the file - calculations were performed, and second one after the disk recording and the renewed opening of the file in SMath Studio. As it is visible after the renewed opening of the file calculation were not executed. Unfortunately I do not know why? I tried to reproduce this situation on many files and different calculations. Unfortunately always with the same result. Probably there is something wrong with the command "desolve"?
Heartily please all for the help in solution of this problem. From above thank you and I greet you very much.
P.S.
Maybe somebody would be able to place on the forum the example-file *.sm on how the use of commands "plot" and "plot3d" in MapleWrapper? Thank you.
No error before recording
Error after recording and the renewed opening .sm file
Edited by user 24 May 2013 18:19:28(UTC)  | Reason: Not specified
Online mkraska
#113 Posted : 24 May 2013 20:19:06(UTC)
mkraska
maple() seems to have problems with matrix expressions. Direct usage of SMath expressions can give wrong results. Translation using maple's matrix operations fails as well (perhaps just a problem with multiply() ).
Edited by user 24 May 2013 20:21:24(UTC)  | Reason: Not specified
File Attachment(s):
Matrix.sm (10kb) downloaded 47 time(s).
on 24/05/2013(UTC),  on 24/05/2013(UTC)
Offline omorr
#114 Posted : 24 May 2013 20:54:33(UTC)
omorr
Serbia
Originally Posted by: sija Go to Quoted Post
Hi Uni!...Probably there is something wrong with the command "desolve"?
I could reproduce this.
By the way, it seems you do not have to use maple() for the assignments - uni told me that Good . See the first picture please.
I think the problem here is the two equal signs. If you recalculate page, or save the file and reopen, this will get lost. In the case of recalculation, the region will be messed up (see the second picture). If you try to select it and move it a bit - it will reappear but without the symbolical result. Just do the calculation manually again (CTRL+.).
It seems that the problem is in this particular recalculation of maple() SMath region with two equal signs.
on 24/05/2013(UTC)
Offline sija
#115 Posted : 24 May 2013 21:30:54(UTC)
sija
Poland
Hi Radovan!
Heartily thank you for your detailed explanation. I greet heartily.
Janusz
Offline uni
#116 Posted : 24 May 2013 21:46:42(UTC)
uni
Updated. Yes, Radovan rights. You must manually retrieve the desired result.
File Attachment(s):
Maple. Example 1.sm (5kb) downloaded 57 time(s).
Russia ☭ forever
Offline sija
#117 Posted : 24 May 2013 21:51:57(UTC)
sija
Poland
I do another example:
No error in this example
In this case after the renewed opening of the file calculation were executed. Why?
Janusz
Offline sija
#118 Posted : 24 May 2013 21:59:26(UTC)
sija
Poland
Hello Uni,
Thank you for new update.
Janusz
Offline uni
#119 Posted : 24 May 2013 22:00:29(UTC)
uni
Janusz
Try this with newer version.
Russia ☭ forever
Offline sija
#120 Posted : 24 May 2013 22:04:40(UTC)
sija
Poland
Uni,
Thank you for your answer. OK I will do.
Janusz
Edited by user 24 May 2013 22:09:45(UTC)  | Reason: Not specified
23 Pages«<45678>»
