4 Pages123>»
Offline Andrey Ivashov
#1 Posted : 01 May 2013 00:16:46(UTC)
Was thanked: 2011 time(s) in 679 post(s)
New SMath Studio 0.96.4868 available
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
SMath Studio Desktop on the Desktop (Windows)
SMath Studio Desktop on the Desktop (Linux)
Last changes
  • New built-in plugin added - ViewerFileType. It allows to create standalone EXE files with all SMath Studio features enabled (localization, plug-ins, etc);
  • Added support for background images for worksheets;
  • Installation type form added to MSI installer (program can be installed even without Administration rights);
  • ARA and KOR interface languages added;
  • Generating of required parentheses improved for symbolic calculations;
  • Fixed error messages on loading program with unmanaged DLLs located in plug-ins directory;
  • Path to worksheet can be used now for creating of import/export plug-ins;
  • SMath Studio file type extended to support file's GUIDs and revision numbers;
  • Print Preview Dialog not shown in Taskbar as a separate window anymore;
  • Fixed issues appears when calling a function with two or more arguments defined by the same variable name or text strings;
  • Incorrect output sign issue fixed for ln(..) function for symbolic library;
  • Simplification of lg(..) function improved for symbolic library;
  • Wrong page size issue fixed when opening Page Setup dialog;
  • Fixed issue appears on typing "product(" function (function drawn with broken layout);
  • Fixed issue appears sometimes on document closing if Worksheet's regions is under evaluation and requests for invalidation (critical exception occurred);
  • Fixed issue appears when evaluating "(1/i)*(1/i)" or similar equations symbolically;
  • Function str2num(..) fixed to correctly parse the result of function num2str(..) on the systems where ',' char is not specified as arguments separator;
  • Symbolic library issue fixed to correctly parse double values with no regards to current system localization;
  • Language files updated;
  • Refactoring.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
    Free Download
    Note: No current version of SMath Studio Handheld release will be introduced. Please use the latest stable handheld version (0.90).
    Tutorial
    • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
    Other files
    SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
    Edited by user 11 May 2013 12:36:26(UTC)  | Reason: Not specified
  • thanks 7 users thanked Andrey Ivashov for this useful post.
    on 01/05/2013(UTC),  on 01/05/2013(UTC),  on 01/05/2013(UTC),  on 01/05/2013(UTC),  on 02/05/2013(UTC),  on 06/05/2013(UTC),  on 08/05/2013(UTC)
    Offline kaka
    #2 Posted : 01 May 2013 00:22:07(UTC)
    kaka
    Rank: Member
    wow, that is great, thank you
    Offline omorr
    #3 Posted : 01 May 2013 00:35:41(UTC)
    omorr
    Serbia
    Was thanked: 319 time(s) in 268 post(s)
    FINALLY !!!
    Friends Good
    Best Wishes,
    Offline kaka
    #4 Posted : 01 May 2013 00:42:25(UTC)
    kaka
    Rank: Member
    why I got a error about malware.qvmo3.gen from my antivirus when I tried the new exe function. I will say my antivirus is too sensitive. Another issue is in the standalone exe file, you state that it is not for commercial use. Is that I cannot use it for my dairy work in company?
    #5 Posted : 01 May 2013 01:01:53(UTC)
    Output EXE contains:
    1) DLLs of SMath Studio
    2) All plugins (DLLs from plugins directory) - even viruses and etc Good
    3) 1 or more language files (based on languages you use in your worksheet)
    4) Created worksheet
    Nothing else. So, I believe it's false detect.
    For now, answer is - yes. Personally I think you can use it for your work if you will not share these output files between your colleagues. Please, note: this is very alpha of EXE file type plug-in.
    Best regards, Andrey Ivashov.
    #6 Posted : 01 May 2013 01:04:36(UTC)
    Glad to see you Radovan! Good
    Hope you'll enjoy new version of SMath Studio.
    BTW: I plan to add some topics here to explain how to use new Backgrounds feature and EXE file type dialog. Today or tomorrow.
    Regards.
    Offline omorr
    #7 Posted : 01 May 2013 01:16:06(UTC)
    omorr
    Serbia
    Hello Andrey,
    I am very happy that you are back! Good
    Hope that you are doing well and there would be no such a long time towards SMath version 1.0 Good
    Best Wishes,
    Offline kaka
    #8 Posted : 01 May 2013 01:25:28(UTC)
    kaka
    Rank: Member
    Then how about the sm files? can I send it to my colleagues? I mainly use it for engineering not for house DIY Good
    #9 Posted : 01 May 2013 01:35:23(UTC)
    Of course you can! Did you read a licence agreement? Good No any restrictions there regarding commercial usage...
    Andrey Ivashov attached the following image(s):
    Offline kaka
    #10 Posted : 01 May 2013 02:19:10(UTC)
    kaka
    Rank: Member
    Yes, That is exactly why I wonder why you have not for commercial use in the new exe plugin.
    Offline mkraska
    #11 Posted : 01 May 2013 03:02:18(UTC)
    mkraska
    Thank you, Andrey, for another update of your great program.
    Updated version with most external plugins
    This is the official linux version augmented by external plugins. Just for convenience.
    Tested on x64 under Win7, at least, there is no complaint on startup and the functions show up. There was just a single conflict: I had to switch the DataExchange Plugin to compact version (without Excel support).
    Offline kaka
    #12 Posted : 01 May 2013 09:06:46(UTC)
    kaka
    Rank: Member
    I got this error when I opened a second Smath
    Offline pol1
    #13 Posted : 01 May 2013 09:17:19(UTC)
    pol1
    Many thanks for the new version.
    when trying to open a *.xmcd file, I get this error message:"could not load file or assembly 'textregion, version=1.9.4868.42191...."
    Offline steveswin
    #14 Posted : 01 May 2013 10:37:03(UTC)
    steveswin
    Rank: Member
    Was thanked: 2 time(s) in 1 post(s)
    Andrey,
    Excellent, glad to see you back in action.
    Steve
    Offline kaka
    #15 Posted : 01 May 2013 10:56:29(UTC)
    kaka
    Rank: Member
    It seems that it only happen to my another PC which has been just reinstalled.
    Offline mkraska
    #16 Posted : 01 May 2013 11:18:55(UTC)
    mkraska
    Have you added the MapleWrapper Plugin yourself? It is not part of the distribution due to license issues with the maple dos exe. Also, it is not localization-proof (cannot handle non-komma settings as argument delimiter).
    EDIT: Also, I guess that it is not safe to open a second SMath with the MapleWrapper plugin in use. The plugin communicates with maple via file I/O, where different instances of SMath might interfere.
    Edited by user 01 May 2013 11:26:42(UTC)  | Reason: Not specified
    Offline kaka
    #17 Posted : 01 May 2013 12:44:35(UTC)
    kaka
    Rank: Member
    The maple works on this machine without this error, I think it might be the problem with my windows patches, I will try it later tonigh and see wether I can get it back to work.
    Another issue is the ClosedXML which come with the Data export pulgin doesn't work any more. Mad
    Offline sija
    #18 Posted : 01 May 2013 12:44:51(UTC)
    sija
    Poland
    Andrey!
    Thank you with all my heart for your work which you put into the creation of this splendid and free programme. Thank you for this new version. I greet you very heartily and I wish all the best!
    Offline mkraska
    #19 Posted : 01 May 2013 13:19:32(UTC)
    mkraska
    The same here. That is why I included the "compact" version of the plugin (without Excel support) in the distribution.
    Offline oscampo
    #20 Posted : 01 May 2013 14:49:45(UTC)
    oscampo
    Colombia
    Was thanked: 124 time(s) in 83 post(s)
    Thank you so much Andrey, very awsome improvements!
    4 Pages123>»
