31 Pages<1234>»
#21 Posted : 28 April 2013 19:57:07(UTC)
Was thanked: 1378 time(s) in 902 post(s)
Could global variables be an option?
The user might define or display values of settings like
XYPlot.xmin:0
XYPlot.xmax:3'm -> this would give the independent variable a unit
XYPlot.ymin:0
XYPlot.ymax:"auto" (auto-scaling)
XYPlot.xaxis:"log" or "lin"
XYPlot.title:num2str(n)
XYPlot.xtics:0,5*'m
etc. This would be quite transparent and readable, but could be hidden in collapsable regions if required.
Settings in the context menu might change or override the variable values or restore them to defaults.
Units could be automatically added to the default axis label if appropriate. You could, however, leave proper annotation in the user's responsibility.
Sticking to some naming convention (e.g. gnuplot) would facilitate the usage.
I think that the easiest way it's to append a unit tag (always or when needed) below the axes tag; something like [ m ] [ - ] [ Pa ]
Offline Ber7
#22 Posted : 29 April 2013 23:03:12(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Eхaple using XYPlot plugin:
Edited by user 29 April 2013 23:22:08(UTC)  | Reason: Not specified
File Attachment(s):
PlotPlugin.smz (10kb) downloaded 126 time(s).
Ber7 attached the following image(s):
thanks 1 user thanked Ber7 for this useful post.
on 30/04/2013(UTC)
Online uni
#23 Posted : 29 April 2013 23:52:26(UTC)
uni
Was thanked: 1382 time(s) in 806 post(s)
Guys, do not rush. The new version will have a slightly different format in the sm-file and your works may not be loaded.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 30/04/2013(UTC)
Online uni
#24 Posted : 30 April 2013 10:45:27(UTC)
uni
Updated.
thanks 4 users thanked uni for this useful post.
on 30/04/2013(UTC),  on 30/04/2013(UTC),  on 30/04/2013(UTC),  on 30/04/2013(UTC)
Offline omorr
#25 Posted : 30 April 2013 11:19:22(UTC)
omorr
Serbia
Hello uni,
To be honest, when I saw this picture from the plugin update - I almost remained speechless Shok
THIS IS AMAZING!!! Yahoo Clapping OK Biggrinancing:
A small issue on my 64bit computer when I opened your example file - the first picture, and my playing on the second Good
Best Wishes,
Online uni
#26 Posted : 30 April 2013 11:28:23(UTC)
uni
Best Wishes,
When you save a file and open it the error also appears?
Show me this line from any of your file or attach it completely:
Code:
<grid gridcolor="192; 192; 255" gridpattern="Dash" gridthickness="1" isxgrid="true" isygrid="true" />
Edited by user 30 April 2013 11:43:46(UTC)  | Reason: Not specified
Offline omorr
#27 Posted : 30 April 2013 11:54:12(UTC)
omorr
Serbia
Best Wishes,
I can not open your example file. If I make my own (like the sample I was playing with) it seems Ok. I can save it and open it again
Code:
I found only this one in the first example I've made.
<grid gridcolor="Brown" gridpattern="Dash" gridthickness="1" isxgrid="true" isygrid="true" />
If you would like me to try anything else in particular, just let me know Good
EDIT: Very good news - after a long time there were Language additions (Lang) Good . I hope that this amazing plugin will have language translations as well
Edited by user 30 April 2013 12:02:22(UTC)  | Reason: Not specified
Online uni
#28 Posted : 30 April 2013 12:12:22(UTC)
uni
Best Wishes,
Code:
Try a different color, and not a system color, something unusual. This error means that the saving format color will be different on different systems, it is bad (for example, I can't open your file).
Unfortunately, I'm afraid not. I don't know how to make a multi-language interface yet.
Offline omorr
#29 Posted : 30 April 2013 12:50:55(UTC)
omorr
Serbia
Here it is,
I tried some custom colors. It is working for me quite well.
Here is the picture and the file which produces it.
P.S. About the language interface, maybe Andrey can do something about it.
File Attachment(s):
proba_colors.sm (5kb) downloaded 102 time(s).
#30 Posted : 30 April 2013 12:59:05(UTC)
Amazing work uni!
You can try to implement the GlobalParams colors functions of Andrey (f.e. the GlobalParams.GetColorByName())
If may help currently I use this class Translator.cs; I think It's the best approach to multilanguage for an external plugin.
Does not work for me...
best regards,
w3b5urf3r
Edited by user 30 April 2013 13:09:55(UTC)  | Reason: Not specified
Online uni
#31 Posted : 30 April 2013 13:20:58(UTC)
uni
Yeah, that's the difference (XY Plot. Example 1.sm):
Code:
and proba_colors.sm:
Code:
<grid gridcolor="255, 128, 128" gridpattern="Dash" gridthickness="1" isxgrid="true" isygrid="true" />
Different system settings. I will correct it. Do not use random colors until I fix it.
Here is another problem. I can't use this technique for translating expressions.
Edited by user 30 April 2013 13:25:04(UTC)  | Reason: Not specified
Online uni
#32 Posted : 30 April 2013 14:28:22(UTC)
uni
I made small changes. Can you try again (XYPlotRegion_20130430r1).
Offline omorr
#33 Posted : 30 April 2013 16:07:44(UTC)
omorr
Serbia
Hmm...it seems some other issue appeared now. I think some fonts issue is involved. This is an error when I tried to open your example file.
However, I can still use it in my computer.
Online uni
#34 Posted : 30 April 2013 17:02:04(UTC)
uni
Ok, it will take time to solve this problem.
on 30/04/2013(UTC)
Offline Ber7
#35 Posted : 30 April 2013 17:12:27(UTC)
Ber7
Israel
Updated.
File Attachment(s):
PlotPlugin.smz (10kb) downloaded 97 time(s).
thanks 2 users thanked Ber7 for this useful post.
Offline omorr
#36 Posted : 30 April 2013 17:53:17(UTC)
omorr
Serbia
Just take your timeGood . We can still make new plots and test it (at least I can).
I tried the file from the post above by Ber7 as well with those nice looking plots. The same "font parsing problem" error appeared.
Any other experience?
Offline mkraska
#37 Posted : 30 April 2013 18:04:03(UTC)
mkraska
Was thanked: 1168 time(s) in 747 post(s)
Great work, uni!
some issues:
- tick spacing should start at zero axis value (now starts at min limit)
- number format for y axis tick values
Double click to access the property page is nice.
File Attachment(s):
xyplot1.sm (5kb) downloaded 110 time(s).
on 30/04/2013(UTC)
Online uni
#38 Posted : 30 April 2013 18:17:52(UTC)
uni
This is global problem and I need to think about how to resolve it correctly.
on 30/04/2013(UTC)
Offline omorr
#39 Posted : 30 April 2013 18:20:34(UTC)
omorr
Serbia
Just in case to mention that I opened the file with two plots made by Martin.
Online uni
#40 Posted : 30 April 2013 18:25:03(UTC)
uni
It can be said in other words. It is a problem of globalization, when you need to share files between countries with different regional standards. I should consult with Andrey to find out how to do it right.
Guest (20)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
31 Pages<1234>»
