23 Pages«<34567>»
Offline uni
#81 Posted : 24 April 2013 23:38:40(UTC)
uni
Was thanked: 1286 time(s) in 751 post(s)
You can use only one command as a parameter to a function maple(). So you can't use the command with(). I have added to the archive file with.inc, it will connect every time when you run maple().
Archive: MapleWrapper_20130425.zip
P.S. Another way.
Edited by user 26 April 2013 12:44:23(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline uni
#82 Posted : 25 April 2013 01:14:55(UTC)
uni
One example.
with.inc:
Code:
restart:with(linalg):with(inttrans):
Edited by user 26 April 2013 11:17:17(UTC)  | Reason: Not specified
Russia ☭ forever
on 25/04/2013(UTC),  on 25/04/2013(UTC)
Offline kaka
#83 Posted : 25 April 2013 23:59:38(UTC)
kaka
Rank: Member
Hi Uni, Thank you but it doesn't work for me. I can see the correct answer in mvr5.txt but Smath showed this error, s is not defined.
Originally Posted by: uni Go to Quoted Post
One example.
with.inc:
Code:
#84 Posted : 26 April 2013 00:48:56(UTC)
Was thanked: 1367 time(s) in 894 post(s)
Have you used the symbolic evaluation? Right-button mouse click and set the optimization option to "Symbolic"
regards,
w3b5urf3r
Offline uni
#85 Posted : 26 April 2013 09:16:23(UTC)
uni
Yes, you must use the symbolic evaluation ( -> ) but not numerical ( = ). In my examples used symbolic evaluation, it is not visible because I changed the view of symbol (from -> to =).
P.S. I can't find now how to change the view of the equal sign. Apparently it was removed in newer versions. For symbolic output you need to press [Ctrl] + [.].
Edited by user 26 April 2013 11:43:43(UTC)  | Reason: Not specified
Russia ☭ forever
#86 Posted : 26 April 2013 14:48:53(UTC)
The arrow was removed in the 0.91 relase; I think that would be useful to visually distinguish between optimiztions, maybe with a little "S" in the top-right corner or over the equal sign....
Edited by user 26 April 2013 15:01:02(UTC)  | Reason: Not specified
Offline kaka
#87 Posted : 26 April 2013 21:30:59(UTC)
kaka
Rank: Member
Clap Finally it works now
Offline uni
#88 Posted : 02 May 2013 15:54:37(UTC)
uni
the maple plugin seems to be partially incompatible with ; and , settings. For me, with , and . the examples work, with ; and , see attached image (generated with plugin version 2012 10 06). Unfortunately I can't remember if I had that problem earlier. Browsing the forum topic I found that there were times that ; and , was the default setting, that seems to have changed.
Switching to , and . is an option in particular cases, but I am writing a handbook in german that entirely demands and assumes ; and , settings.
Best regards, Martin Kraska
Updated. Try again.
Russia ☭ forever
on 02/05/2013(UTC),  on 03/05/2013(UTC)
Offline sija
#89 Posted : 02 May 2013 21:15:41(UTC)
sija
Poland
Hello Uni,
Finally the MapleWrapper_20130502 works for me. Thank you for this new version.
Greetings!
Offline mkraska
#90 Posted : 03 May 2013 00:57:00(UTC)
mkraska
Was thanked: 1149 time(s) in 737 post(s)
Updated. Try again.
Much better than before. Thank you for the great work.
I tried the examples:
parse.sm generates formatting problems, the error message says that "Index and length have to refer to a position in the string"
in MapleWrapper_Examples, all functions involving strings fail with the same error message, everything else is fine.
Offline uni
#91 Posted : 03 May 2013 01:10:54(UTC)
uni
Updated. Try again.
Yes, this problem is present. I haven't found a good way to make the parsing more flexible. Working on it.
Russia ☭ forever
Offline sija
#92 Posted : 04 May 2013 01:35:30(UTC)
sija
Poland
Hello!
I got an error like in this example below:
Error:
Janusz
[Moderator]: Moved.
Edited by moderator 04 May 2013 02:43:24(UTC)  | Reason: Not specified
Offline omorr
#93 Posted : 04 May 2013 01:55:36(UTC)
omorr
Serbia
Hello Janusz,
That's strange. I can not reproduce this. It works for me.
Offline mkraska
#94 Posted : 04 May 2013 02:00:43(UTC)
mkraska
I confirm that. The error message is "Error, (in smath_diff) wrong number (or type) of parameters in function diff|ans"
This error does not happen with . as dec separator and , as arg separator. Thus we have still localization problems with maplewrapper.
Offline omorr
#95 Posted : 04 May 2013 02:09:47(UTC)
omorr
Serbia
It seems you are right Martin. One more confirmation that this problem still persist, in spite of unis' efforts.
Edited by user 04 May 2013 02:20:32(UTC)  | Reason: Not specified
Offline uni
#96 Posted : 04 May 2013 02:18:27(UTC)
uni
I specially do output to a log file. It is desirable in all such cases to show the contents of the file \plugins\mvr5\mvr5.txt.
Russia ☭ forever
Offline mkraska
#97 Posted : 04 May 2013 02:21:37(UTC)
mkraska
Here you are.
File Attachment(s):
mvr5.txt (2kb) downloaded 44 time(s).
#98 Posted : 04 May 2013 02:28:03(UTC)
I think that the latest posts should be moved in the MapleWrapper thread to avoid confusion for Andrey on debugging SMath. Rolleyes
on 04/05/2013(UTC)
Offline uni
#99 Posted : 04 May 2013 02:36:16(UTC)
uni
Try to use the el() function instead of a point: maple(diff(diff(f(x);el(x;1));el(x;2))).
Code:
maple(diff(diff(f(x);el(x;1));el(x;2))) - copy and paste to SMath Studio
In log file you will see:
Code:
[->] smath_diff(smath_diff(smath_el(x,1)^3+smath_el(x,2)^2,smath_el(x,2)),smath_el(x,1))
P.S. I didn't know that Maple understands this entry. I didn't plan to support this form of the equation.
Edited by user 04 May 2013 03:07:28(UTC)  | Reason: Not specified
Russia ☭ forever
Offline sija
#100 Posted : 04 May 2013 12:59:40(UTC)
sija
Poland
Hello!
Martin, thank you for your explanations concerning this error, I made the change in settings SMath Studio - according to your advices, and all is already well.
Janusz
23 Pages«<34567>»
