Offline Dham
#1 Posted : 24 April 2013 01:29:07(UTC)
Dham
Rank: Member
Brazil
would be very useful to me, and maybe for most mechanical, chemical, civil (e other) engineers (and students, of course) to have internal material data inside Smath (maybe, as a plugin).
This feature, with some nonlinear system solver with units support, would turn Smath into a nice alternative to EES (http://www.fchart.com/ees/)
For small calculations, you can put some table data in a matrix, and use submatrix and cols functions to extract the vectors to be interpolated, but it may be very time consuming, and you have to be very careful about units.
A workaround is to create various snippets, one for each Property and Material (SuperHeatedSteam_Enthalpy, Air_density...) with internal function, similar to the attachment, or create a complicated snippet with all data about a material, with the bult-in functions for properties (this would be probably the closest to the plugin code, but would turn the smallest calculation into a huge worksheet)..
The problem is that some tables are more complicated to interpolate, like this: http://server.fst.uga.ed...ated%20Steam%20Table.jpg (what if I want Enthalpy for lets say, 45kPa and 156ºC? It's just an example, anyway)..
Also, not all users may want to spend time to create so many snippets, or know which internal functions to use to achieve his goal, so a plugin like this would help a lot (and probably bring lots and lots of users Biggrin ).
Sorry about my english, it's getting rust,
Danilo Monteiro
File Attachment(s):
Example.sm (17kb) downloaded 145 time(s).
Offline mkraska
#2 Posted : 24 April 2013 02:20:17(UTC)
mkraska
You may have a look at the following topic.
The plugin does not work for me, but you may be more successful (the plugin seems to be x64-incompatible)
Offline Dham
#3 Posted : 24 April 2013 02:44:46(UTC)
Dham
Rank: Member
Brazil
Oh, that may help.
But we could not extend it (add tables for other fluids, etc.)
Anyway, if this work, will be one less snippet to create, thanks!
__________________________________________________________________
It didn't work Sad
Edited by user 24 April 2013 02:50:38(UTC)  | Reason: Not specified
Offline kilele
#4 Posted : 24 April 2013 03:23:01(UTC)
kilele
I don't know what happened to xsteam at www.x-eng.com (seems offline), it had dll files, excel files and other components.
Anyway I've found this code which might be useful in the future to make a plugin.
http://www.mathworks.com...entral/fileexchange/9817
The DataExchange plugin could be used in a smath snippet to import data from the xsteam excel sheet.
Edited by user 24 April 2013 03:41:48(UTC)  | Reason: Not specified
Offline Dham
#5 Posted : 24 April 2013 04:12:59(UTC)
Dham
Rank: Member
Brazil
I found these sources about xsteam:
https://sourceforge.net/projects/xsteam/
http://xsteam.sourceforge.net/
But the download links are directing to the offline site Sad
Offline kilele
#6 Posted : 24 April 2013 16:11:21(UTC)
kilele
I found XSteam in excel, odf, matlab and dll versions:
XSteam_v2.6_excel_ods_matlab_dll.zip
An there you have a couple of derivatives based on xsteam:
http://www.me.ua.edu/ExcelinME/thermo.htm
http://www.chemsof.com/spreadsheet.htm
The University of Alabama's derivative of XSteam looks sweet (see youtube video), don't know if it'd be possible grab their excel macros code to make a SMath plugin (if permission is granted of course)
Edited by user 27 April 2013 13:48:32(UTC)  | Reason: Not specified
Offline Dham
#7 Posted : 26 April 2013 06:31:25(UTC)
Dham
Rank: Member
Brazil
This implementation look way more complicated than table interpolation Sad
http://www.iapws.org/relguide/IF97-Rev.pdf
Also, is only for water/steam..
Edited by user 26 April 2013 06:33:05(UTC)  | Reason: Not specified
Offline uni
#8 Posted : 26 April 2013 11:03:59(UTC)
uni
Yes, it is possible through a VB.Net plugin.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline kilele
#9 Posted : 26 April 2013 20:10:21(UTC)
kilele
Well it is different from your interpolating approach and just for water but it could be extended with other resources. It would be a nice occasion to see SMath handling units, maybe the NonlinearSolvers plugin would come in handy.
XSteam is a well regarded resource in some universities from USA, Spain and Italy (I found the ods version in a engineering department from Italy).
It is only for water yet useful in lots of energy/exergy efficiency analysis like this one in excel:
http://personales.upv.es...a/CT/T4/SCE1_2012res.xls
The derivative work from the University of Alabama includes also a couple of refrigerants, which could show us the direction to consider more substances, either by using correlations or interpolating tabular data as you suggested.
Fine, I meant the possibility of porting the actual macros into C# code.
For now I lack coding skills ^^ but this reference could be useful in the future:
"VSTO, visual studio tools for office","convert vba to vb.net"
Migrating an Excel VBA Add-in to a VB.Net XLL with Excel-Dna
Edited by user 27 April 2013 13:52:07(UTC)  | Reason: Not specified
Offline Dham
#10 Posted : 27 April 2013 05:58:05(UTC)
Dham
Rank: Member
Brazil
Edit:
There was a dll version but can't find it.
I agree with you, interpolation it's just the easiest way (for me) to do. Another thing to take account of is that a lot of data tables would make this plugin use too much of disk space and system memory. Interpolation is more suitable for code snippets, I think.
Probably EES (the software I mentioned before) uses only correlations, it's a small install package and have lots and lots of features.
My coding skills are limited to some numeric calculations (mainly scilaCool, I can't help much in this plugin's development besides testing.... :'(
Offline kilele
#11 Posted : 27 April 2013 13:53:29(UTC)
kilele
I found XSteam dll version!
Updated download link.
Edited by user 27 April 2013 13:55:49(UTC)  | Reason: Not specified
Offline kilele
#12 Posted : 28 April 2013 05:20:03(UTC)
kilele
I've just read that EES supports hundreds of fluids..well we could prepare some table data and compare it with that software. I think it would be possible to make such tables by digitizing thermodynamics graphs with this software:
Engauge Digitizer
Engauge Digitizer tutorial
Then you could interpolate between values stored in each table or obtain spline functions.
Edited by user 28 April 2013 05:35:09(UTC)  | Reason: Not specified
Offline kilele
#13 Posted : 03 May 2013 03:38:22(UTC)
kilele
I've found these libraries for computing water properties using IAPWS-IF97 formulation :
Properties of water DLL coded in C#
Freesteam
And these are other .net libraries which might be useful:
CoolProp Property database that includes pure fluids, pseudo-pure fluids, and humid air properties.
Nature. API for computing physical properties of complex gas mixtures.
Edited by user 19 July 2013 14:48:57(UTC)  | Reason: Not specified
thanks 2 users thanked kilele for this useful post.
on 03/05/2013(UTC),  on 03/05/2013(UTC)
