Hi, this is a sample made by Radovan on how to repeat calculations but using mat2sys and sys2mat from the customFunctions pluginAnother way of creating tabular data. File Attachment(s): kilele attached the following image(s):
2 users thanked kilele for this useful post.
on 12/04/2013(UTC), on 12/04/2013(UTC)
Some care is required when creating tables by application of functions to lists (systems). If more than one list or more than one occurance of a list is involved in the expression to apply, then the resulting list contains all possible combinations of elements from the individual lists and the resulting length is a power of the input list length. There may be unexpected effects of symbolic optimization of the function definition. At least, symbolic and numeric optimization may result in different list sizes. In the example, symbolic optimization results in storage of 2*x instead of x+x thus reducing the number of list occurences and thereby the size of the result. Edited by user 12 April 2013 00:54:17(UTC)
| Reason: Not specified File Attachment(s): mkraska attached the following image(s): |
2 users thanked mkraska for this useful post.
Thanks! so I was quite wrong as of suggesting systems to create tables. It is error-prone because most of the time one wants to compute several lists on the same expression. Edited by user 12 April 2013 02:40:46(UTC)
1 user thanked kilele for this useful post.
Originally Posted by: kilele Thanks! so I was quite wrong as of suggesting systems to create tables. It is error-prone because most of the time one wants to compute several lists on the same expression. I would not go that far to say the suggestion was wrong. The procedure is safe and convenient as long as you know what you are doing. However, people just seeing such examples may wrongly generalize to expressions with multiple list occurences. It would help a lot if implicit looping with index vectors just as in Mathcad was available. |
