Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
2013
2 users thanked Ber7 for this useful post.
on 30/12/2012(UTC), on 03/01/2013(UTC)
optical illusionThe idea is taken from the site http://www.mapleprimes.com/mapl...71-Its-Better-With-MapleAlthough the vertical distance between the curves is constant, it seems that with increasing distance from the axis of Y, they are getting closer. Animation helps to overcome this optical illusion
1 user thanked Ber7 for this useful post.
Rolling disk on a parabola
on 02/03/2013(UTC), on 28/07/2013(UTC)
on 28/07/2013(UTC), on 28/07/2013(UTC)
on 12/09/2013(UTC), on 16/09/2013(UTC)
Challenge for Ber7 This would be a great SMath animation : Heatherwick's Rolling BridgeSee it in action on this video at 1 minute and 25 seconds : ?t=1m25s Edited by user 16 September 2013 15:53:34(UTC)
| Reason: Not specified
2 users thanked kilele for this useful post.
on 16/09/2013(UTC), on 16/09/2013(UTC)
Thank you for the wonderful example . I'll try to implement it.
The Rolling Bridge
3 users thanked Ber7 for this useful post.
on 19/09/2013(UTC), on 19/09/2013(UTC), on 26/09/2013(UTC)
Was thanked: 3 time(s) in 2 post(s)
Nice, Rolling Bridge! See you this: The author Regards
2 users thanked lrcvs for this useful post.
on 26/09/2013(UTC), on 26/09/2013(UTC)
Animation examples from the book “Introduction to Statics and Dynamics by Rudra Pratap, Andy Ruina.Publisher: Cornell University 2009” http://ruina.tam.cornell...k/RuinaPratap8-21-10.pdf A spring-mass system in spaceA spring-mass system consists of two masses, m1 = 10 kg and m2 = 1 kg, and a weak spring with stiffness k = 1N/m. The spring has zero relaxed length.The system is in 3-D space where there is no gravity. Track the motion of the system for the next 20 seconds. Plot the trajectory of the two masses in space. The 3-D animation showing the trajectory of the two masses obtained from the numerical solution . From the plot, it seems like the smaller mass goes around the bigger mass as the bigger mass moves on its trajectory. Edited by user 03 October 2013 15:20:20(UTC)
Joined: 18/05/2010(UTC) Posts: 27 Was thanked: 13 time(s) in 6 post(s)
Thank you very much, corrected.
Animation of NPlot and 3d Plot graphsThe program is designed for graphs that do not have a built-in animation capabilities 3dplot mk.sm (9kb) downloaded 29 time(s). NplotAnimation.sm (15kb) downloaded 32 time(s).Edited by user 27 November 2020 10:40:32(UTC)
