10 Pages«<8910
Online uni
#181 Posted : 27 October 2024 02:25:46(UTC)
uni
Was thanked: 1382 time(s) in 806 post(s)
Coming soon...
The ability to explicitly specify the placement of block elements will be added.
It looks strange, maybe I'll add some numbering: #1, #2, #3, ...
Edited by user 27 October 2024 02:32:33(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
Offline Razonar
#182 Posted : 27 October 2024 15:34:21(UTC)
Razonar
Uruguay
Was thanked: 931 time(s) in 591 post(s)
Originally Posted by: uni Go to Quoted Post
... It looks strange, maybe I'll add some numbering: #1, #2, #3, ...
Hi. That's the Mathematica default notation for pure function's arguments: https://reference.wolfra...rkWithPureFunctions.html
on 27/10/2024(UTC)
Online uni
#183 Posted : 13 November 2024 09:47:53(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- fixed image handling functions (READRGB(),...);
- the appearance of brackets has been changed;
- added the ability to explicitly specify an insert for MathcadBlock (##, #1, #2, ...).
mathcadblock-explicit-paste.sm (16kb) downloaded 10 time(s).
Edited by user 13 November 2024 22:12:58(UTC)  | Reason: Not specified
on 13/11/2024(UTC)
Online uni
#184 Posted : 13 November 2024 22:42:40(UTC)
uni
Expanding the idea of ​​numbering, we can add syntax:
## - take all as sys|mat|line
#i#j - take from i to j
##j - take from 1 to j
#i# - take from i to end
and
#i#js - sys(#i,..,#j)
#i#jm - mat(#i,..,#j)
#i#jl - line(#i,..,#j)
#i#jfun - fun(#i,..,#j)
or
### - insert as parameters: foo(x,y,###) -> foo(x,y,#1,#2,...)
##3# - insert as parameters: foo(x,y,##3#) -> foo(x,y,#1,#2,#3)
Offline mkraska
#185 Posted : 14 November 2024 05:20:14(UTC)
mkraska
Was thanked: 1168 time(s) in 747 post(s)
I encountered a plot problem with the list version of rkfixed(). Probably this also applies to other ODE-integrators with embedded function assignment.
In the native 2D Plot:
- When plotting a solution function along with a matrix of marker points, then the points won't display
- Yet, when using lspline() directly, both objects plot without problems.
In X-Y Plot:
- When the independent variable has the same name as the solution function (e.g. x(x), then x() is not treated as a function but as the expression x (similar with v(v) or any other name).
- A workaround is to use a variable name different from the function name. Yet this is strange, because in SMath x() and x usually are independent objects.
plotproblem.sm (31kb) downloaded 4 time(s).
on 14/11/2024(UTC)
Offline Razonar
#186 Posted : 14 November 2024 07:45:31(UTC)
Razonar
Uruguay
A little step further? (And I say little because I'm not the one who has to improve the code) Take #arg as function parameter?
on 14/11/2024(UTC)
Online uni
#187 Posted : 15 November 2024 09:34:05(UTC)
uni
Plugin updated.
Changes:
- MathcadBlock: the syntax for explicit insertion has been extended.
Edited by user 15 November 2024 09:42:56(UTC)  | Reason: Not specified
on 16/11/2024(UTC)
Online uni
#188 Posted : 15 November 2024 11:14:39(UTC)
uni
Crazy
mathcadblock-alnleqsolve.sm (13kb) downloaded 6 time(s).
Edited by user 15 November 2024 11:17:14(UTC)  | Reason: Not specified
on 16/11/2024(UTC)
Offline mkraska
#189 Posted : 15 November 2024 22:11:09(UTC)
mkraska
Visualization of transformations and matrix norms using implicit plots and automatic scaling of the X-Y plots.
Matrixnormen 2D.sm (29kb) downloaded 10 time(s).
thanks 3 users thanked mkraska for this useful post.
on 15/11/2024(UTC),  on 15/11/2024(UTC),  on 16/11/2024(UTC)
10 Pages«<8910
