29 Pages«<2526272829>
Online uni
#521 Posted : 14 December 2023 03:39:41(UTC)
uni
Was thanked: 1304 time(s) in 763 post(s)
SMath Studio compatibility
Plugin updated.
Changes:
- fixed: when cloning a component and changing its name, the function setprop() doesn't work.
Russia ☭ forever
Viacheslav N. Mezentsev
on 28/02/2024(UTC)
Offline TopUser2000
#522 Posted : 26 February 2024 02:21:53(UTC)
TopUser2000
Rank: Member
Belarus
Originally Posted by: uni Go to Quoted Post
Plugin updated.
Is there a fucntion of autoscale? To find the plot as soon as it's created
Edited by user 26 February 2024 05:00:39(UTC)  | Reason: Not specified
Online uni
#523 Posted : 27 February 2024 21:31:29(UTC)
uni
There is no automatic detection of curve boundaries.
Russia ☭ forever
Offline TopUser2000
#524 Posted : 01 March 2024 20:08:46(UTC)
TopUser2000
Rank: Member
Belarus
Are you planning to add this? Or is it impossible?
Online uni
#525 Posted : 02 March 2024 02:30:45(UTC)
uni
It's possible, but I don't know what to do in special cases. For example, if I want to draw a circle in an implicit way, how can I determine its boundaries.
Russia ☭ forever
Offline Razonar
#526 Posted : 04 March 2024 06:51:10(UTC)
Razonar
Uruguay
Was thanked: 884 time(s) in 560 post(s)
Hi. Although setprop provides the ability to adjust the limits, it disables formatting the graph with the menus. An intermediate and easily accessible solution would perhaps be to be able to define the window where you want to view the functions to be graphed with something like what is shown in the figure.
Notice also that there is no automatic selection for the range on the x-axis for functions of a variable, that is, it always has to be selected by the user, and on the y-axis it can become something quite arbitrary, as it can be in graph of y=1/x.
Edited by user 04 March 2024 06:58:37(UTC)  | Reason: Not specified
Offline TopUser2000
#527 Posted : 29 March 2024 05:14:15(UTC)
TopUser2000
Rank: Member
Belarus
You can do this experimentally and disabled by default. If a graph is being built, its extreme points are determined (top-bottom, right-left), 5-10% of the coordinate values are added (if the left or bottom point is 0, then the axis starts from zero) and the graph is scaled.
You can add horizontal, vertical, or both axis scaling
Online uni
#528 Posted : 29 March 2024 19:54:12(UTC)
uni
Click to enlarge
How to autoscale in these and similar cases? It makes sense to change sources if the architecture of the changes has a general form, and not a lot of particulars. The developer must consider multiple use cases, as users will then ask why it only works in one or a few cases.
Edited by user 29 March 2024 19:59:50(UTC)  | Reason: Not specified
Russia ☭ forever
Offline TopUser2000
#529 Posted : 30 March 2024 07:38:01(UTC)
TopUser2000
Rank: Member
Belarus
Click to enlarge
In this case, you can write "the boundaries of the graph could not be determined". That's it!)
Offline wb.c
#530 Posted : 02 April 2024 04:40:03(UTC)
wb.c
Was thanked: 25 time(s) in 21 post(s)
Any way to plot a string at a specified angle?
Offline Razonar
#531 Posted : 23 May 2024 19:51:07(UTC)
Razonar
Uruguay
Hi. You can try this. Just move the "Fonts" area from the end to the beginning.
Online uni
#532 Posted : 10 August 2024 00:04:03(UTC)
uni
setprop-simplified example setprop-simplified example
A simplified version of setting properties will be available when the release manager is fixed.
Click to enlarge Click to enlarge
Edited by user 10 August 2024 03:34:15(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ioan92
#533 Posted : 11 August 2024 01:49:03(UTC)
ioan92
France, Metropolitan
Was thanked: 164 time(s) in 128 post(s)
Hi Uni,
May I come to you with a small proposal concerning this excellent plugin.
My proposal concerns the "Shapes Drawings". Would it be possible to fill a polygon also with transparent collors ?
Thanks a lot and best Regards,
Ioan
Online uni
#534 Posted : 11 August 2024 04:33:58(UTC)
uni
What's wrong with this method? You can always use transparency. Color format: #ARGB.
Russia ☭ forever
on 13/08/2024(UTC)
Offline ioan92
#535 Posted : 11 August 2024 04:39:18(UTC)
ioan92
Thanks for your answer.
Here is my application's result:
Edited by user 12 August 2024 04:30:11(UTC)  | Reason: Not specified
Online uni
#536 Posted : 13 August 2024 17:48:24(UTC)
uni
SMath Studio compatibility setprop-simplified example setprop-simplified example
Plugin updated. Ctrl+Shift+K for special symbols ( '.','{','}' ).
Changes:
- added a simplified version of setting properties;
- added support for nesting for easier property setting;
- simplified nested example added.
Edited by user 14 August 2024 02:22:51(UTC)  | Reason: Not specified
Russia ☭ forever
thanks 4 users thanked uni for this useful post.
on 13/08/2024(UTC),  on 13/08/2024(UTC),  on 14/08/2024(UTC),  on 15/08/2024(UTC)
Offline kaizh
#537 Posted : 14 August 2024 18:34:17(UTC)
kaizh
Rank: Member
China
Was thanked: 3 time(s) in 1 post(s)
thanks uni , it's so convenient to set properties for figures now ,
i wil attach my usage for late-comers to reference .
i decide to make it be a snippet , whenever there is a xyplot i'll insert this snippet
Clap
my sm file is at: simplifed_setprop.sm (14kb) downloaded 12 time(s).
Edited by moderator 14 August 2024 18:43:23(UTC)  | Reason: Not specified
thanks 3 users thanked kaizh for this useful post.
on 14/08/2024(UTC),  on 14/08/2024(UTC),  on 14/08/2024(UTC)
Online uni
#538 Posted : 14 August 2024 23:04:06(UTC)
uni
From now the old ways of managing the plot settings from the document will be considered obsolete. In the future, I will disable and remove them.
I might remove the curly braces on the left. They're not really necessary. Right now, the source code from the setprop() function is used.
Edited by user 14 August 2024 23:10:01(UTC)  | Reason: Not specified
Russia ☭ forever
Offline mkraska
#539 Posted : 15 August 2024 01:43:21(UTC)
mkraska
Was thanked: 1153 time(s) in 739 post(s)
I'd propose to add an option to send the current settings of a plot to the clipboard as math regions. Then the user can paste this to the sheet and delete/modify as needed.
on 15/08/2024(UTC),  on 15/08/2024(UTC)
Online uni
#540 Posted : 13 September 2024 08:50:31(UTC)
uni
As an experiment, I may add this feature.
Russia ☭ forever
on 13/09/2024(UTC)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
