Joined: 05/05/2023(UTC) Posts: 11  Location: Milan Was thanked: 1 time(s) in 1 post(s)
Hi everybody! I've got a problem with smath and I'd like to share with you The problem is just in my computer, with other laptop there are not any issue. If I open any files and try to edit in the "format" windows the graph i'm not able to visualize it. The program doesn't work like if the windows is open somewher. I need to push enter as to give "ok" in the "ghost window" Is maybe some setting that I have casually touch? Somebody had the same problems and solved it in someway with some key combinations?
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,728   Location: Italy Was thanked: 1396 time(s) in 910 post(s)
I think it might be something related to multi-window (peraphs a popup location saved in one configuration and not compatible with another) P.S. Please whatever you post, submit it in the correct section; either Bugs & Problems or Questions would have been the appropriate section in this case. |
Ah okok, next time i'll post in the correct place sorry
