  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 433   Was thanked: 46 time(s) in 41 post(s)
Originally Posted by: OchkovVF  The graph you've provided seems to show a relationship between two pressures 𝑝1and 𝑝2, with annotations related to efficiency calculations. Axes:𝑝1 on the x-axis (measured in atm). 𝑝2 on the y-axis (measured in atm). Curves: Different colored curves (red, blue, and green) that might represent different states or processes in a thermodynamic cycle or system, such as isobars, isotherms, or other state transitions. Water/Steam Cycle: Given the mention of "WaterSteame Pro," this graph might be related to a water/steam cycle analysis, such as a Rankine cycle or steam turbine efficiency calculation. Efficiency (𝜂): The efficiency calculations likely relate to the performance of a particular component or the overall system under different pressures and temperatures. The mention of "points > 20 - problems" suggests there might be issues with the data points or calculations when exceeding a certain number of data points.
 1 user thanked pepperyalready for this useful post.
Joined: 28/08/2014(UTC) Posts: 1,513  Was thanked: 976 time(s) in 610 post(s)
on 24/07/2024(UTC), on 24/07/2024(UTC)
My solution
