27 Pages«<252627
Offline uni
#521 Posted : 14 December 2023 03:39:41(UTC)
uni
Was thanked: 1279 time(s) in 747 post(s)
SMath Studio compatibility
Plugin updated.
Changes:
- fixed: when cloning a component and changing its name, the function setprop() doesn't work.
Russia ☭ forever
Viacheslav N. Mezentsev
on 28/02/2024(UTC)
Offline TopUser2000
#522 Posted : 26 February 2024 02:21:53(UTC)
TopUser2000
Rank: Member
Belarus
Originally Posted by: uni Go to Quoted Post
Plugin updated.
Is there a fucntion of autoscale? To find the plot as soon as it's created
Edited by user 26 February 2024 05:00:39(UTC)  | Reason: Not specified
Offline uni
#523 Posted : 27 February 2024 21:31:29(UTC)
uni
There is no automatic detection of curve boundaries.
Russia ☭ forever
Offline TopUser2000
#524 Posted : 01 March 2024 20:08:46(UTC)
TopUser2000
Rank: Member
Belarus
Are you planning to add this? Or is it impossible?
Offline uni
#525 Posted : 02 March 2024 02:30:45(UTC)
uni
It's possible, but I don't know what to do in special cases. For example, if I want to draw a circle in an implicit way, how can I determine its boundaries.
Russia ☭ forever
Offline Razonar
#526 Posted : 04 March 2024 06:51:10(UTC)
Razonar
Uruguay
Was thanked: 849 time(s) in 536 post(s)
Hi. Although setprop provides the ability to adjust the limits, it disables formatting the graph with the menus. An intermediate and easily accessible solution would perhaps be to be able to define the window where you want to view the functions to be graphed with something like what is shown in the figure.
Notice also that there is no automatic selection for the range on the x-axis for functions of a variable, that is, it always has to be selected by the user, and on the y-axis it can become something quite arbitrary, as it can be in graph of y=1/x.
Edited by user 04 March 2024 06:58:37(UTC)  | Reason: Not specified
Offline TopUser2000
#527 Posted : 29 March 2024 05:14:15(UTC)
TopUser2000
Rank: Member
Belarus
You can do this experimentally and disabled by default. If a graph is being built, its extreme points are determined (top-bottom, right-left), 5-10% of the coordinate values are added (if the left or bottom point is 0, then the axis starts from zero) and the graph is scaled.
You can add horizontal, vertical, or both axis scaling
Offline uni
#528 Posted : 29 March 2024 19:54:12(UTC)
uni
Click to enlarge
How to autoscale in these and similar cases? It makes sense to change sources if the architecture of the changes has a general form, and not a lot of particulars. The developer must consider multiple use cases, as users will then ask why it only works in one or a few cases.
Edited by user 29 March 2024 19:59:50(UTC)  | Reason: Not specified
Russia ☭ forever
Offline TopUser2000
#529 Posted : 30 March 2024 07:38:01(UTC)
TopUser2000
Rank: Member
Belarus
Click to enlarge
In this case, you can write "the boundaries of the graph could not be determined". That's it!)
Offline wb.c
#530 Posted : 02 April 2024 04:40:03(UTC)
wb.c
Was thanked: 25 time(s) in 21 post(s)
Any way to plot a string at a specified angle?
Offline Razonar
#531 Posted : 23 May 2024 19:51:07(UTC)
Razonar
Uruguay
Hi. You can try this. Just move the "Fonts" area from the end to the beginning.
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
27 Pages«<252627
