Offline OchkovVF
#1 Posted : 29 January 2024 22:41:35(UTC)
OchkovVF
Was thanked: 46 time(s) in 41 post(s)
When x1(t)=sin(t) - no problem.
When x1(t) is my function - an error!
See please the attach.
Three-Planets (Mathcad Block).sm (39kb) downloaded 11 time(s).
Offline mkraska
#2 Posted : 29 January 2024 23:31:21(UTC)
mkraska
This is because the solution functions are defined using interpolation. The interpolation functions have the X and Y vectors and the value of x as arguments. You try to provide a vector for x. Vectorize can handle only matrix arguments of the same size and successively calls the function with the j-th element of each vector.
So vectorize would require your x vector to be of the same size as the data vectors. Even in this case this probably will fail because the data would be reduced to a single X_i and Y_i.
Therefore, you have to use a loop.
#3 Posted : 30 January 2024 05:12:24(UTC)
Vectorize works fine in this document.
Three-Planets.sm (42kb) downloaded 10 time(s).
Offline OchkovVF
#4 Posted : 30 January 2024 06:28:13(UTC)
OchkovVF
Sorry - no. See please the attach
Three-Planets.sm (40kb) downloaded 17 time(s).
#5 Posted : 31 January 2024 03:47:53(UTC)
As I open your returned document,
both vectorize are red ... click on either one ... Bingo
