Offline oscampo
#1 Posted : 18 September 2023 17:31:30(UTC)
oscampo
Colombia
Was thanked: 89 time(s) in 68 post(s)
Here is a problem I found trying to solve a simple engineering question.
Please see attached file: Problem with solvers.sm (91kb) downloaded 11 time(s).
Edited by user 20 September 2023 21:56:52(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 19 September 2023 03:17:56(UTC)
Turkey
Was thanked: 516 time(s) in 344 post(s)
Sorry I don't have maxima.
Equations are solved with FindRoot().
I also had to make some alterations.
Original y(x) function has unit mismatch.
Solvers don't like direct usage of if() or cases().
You can detect it with Unknowns().
If it doesn't produce a result, there is a problem.
Here is your file solved.
Problem with solvers_solved.sm (96kb) downloaded 12 time(s).
thanks 5 users thanked overlord for this useful post.
on 19/09/2023(UTC),  on 19/09/2023(UTC),  on 19/09/2023(UTC),  on 19/09/2023(UTC),  on 19/09/2023(UTC)
Offline overlord
#3 Posted : 20 September 2023 02:53:43(UTC)
Turkey
I assumed C.1 and C.2 has same units.
Maybe I was wrong at that conclusion.
Worksheet below find a solution between 4-6.
This may be the correct result.
Sorry if I made a huge mistake.
Problem with solvers_revisited.sm (106kb) downloaded 10 time(s).
Click to enlarge
Edited by user 20 September 2023 02:56:38(UTC)  | Reason: Not specified
thanks 2 users thanked overlord for this useful post.
on 20/09/2023(UTC),  on 20/09/2023(UTC)
Offline oscampo
#4 Posted : 20 September 2023 03:24:06(UTC)
oscampo
Colombia
Perfect! Thanks for your cooperation!
