SMath Studio Forum
Download SMath Studio
Stable: SMath Studio 1.0.8348 (09 November 2022)
Joined: 17/06/2020(UTC) Posts: 7 Location: Sint-Niklaas
Originally Posted by: Andrey Ivashov Thank you!
I just want to add that this small requirement to activate SMath Studio is a huge step to make this software much more powerful in the nearest future.
Why? I will try to explain: I've created a company in Russia and we have a brilliant team of 3 programmers (strong in IT, math, physics). We were able to monetize a project and working hard to make our first clients happy (licensing server, courses, planning and features for companies). We are going to finish our current activities in a Month or two and then will start improve SMath Studio itself: new graphs, stable Writer, performance of the numeric/symbolic calculation engines, new files format (modern and stable) and much more - that is what we will do in 2023.
Hope you'll enjoy the results. I just asking to activate a program for free! Nothing more...
Best regards, Andrey Ivashov. Good luck with the project. Do you intend on limiting what is available for free now as a business model? Or do you want to make money by improving further the premium features? Edit: found here: https://en.smath.com/for...ions--ANSWER--IT-IS.aspxIn any case, I'd be interested to know if it would be possible to purchase a premium feature abroad. Edited by user 23 December 2022 19:25:48(UTC)
| Reason: Not specified
Very good update for the desktop version , but it would be nice to add a small function in the mobile version (.apk), to view and report as a .pdf or .jpg file, the already prepared spreadsheets in the desktop version.
Joined: 02/04/2018(UTC) Posts: 152 Was thanked: 25 time(s) in 21 post(s)
So, just to understand things. With SMath Viewer, in order to remove the water mark when printing from a complied exe, you must be subscribed? Even if you have "activated" SMath, when you save a sheet as an exe, and then print from the exe, you get the watermark. Edited by user 14 March 2023 00:06:25(UTC)
Any possibility of a version for Mac???? Thnx
I am new to Smath. I was trying to open Mathcad file (.xmcd file). The page went blank. Would you help? Thank you.
Hi, Andrey
I am new to Smath and learning the software. I would like to import Mathcad file (.xmcd file). When I opened it in Smath, the page went blank (nothing shown).
Would you provide some guidances.
Also, some users posted some Smath files. I tried to download them but somehow I was not able to click on the file name. Did I miss anything?
Thank you.
Basri
Joined: 15/04/2012(UTC) Posts: 2,023 Was thanked: 1153 time(s) in 739 post(s)
If you use the windows installer, then you should be able to double-click .sm files in the file manager. You also can drag .sm files from the file manager to an open SMath instance. Or you use the file menu> open> navigate to your file.
Perhaps you tried all this already because it is standard windows program behaviour. So the problem might be something else. |
Hi, Martin
Thank you for the response. I will try that.
Is there a way to import Mathcad file to SMath? I tried to open it in Smath, but it did not show anything (blank page in SMath).
Thank you again
Basri
Joined: 28/08/2014(UTC) Posts: 1,432 Was thanked: 885 time(s) in 561 post(s)
Originally Posted by: basri ... Is there a way to import Mathcad file to SMath? I tried to open it in Smath, but it did not show anything (blank page in SMath) ... Hi Basri. From the start of this thread, on Miscellaneous: "XMCD plug-in removed from the standard installer". So, you need to install it from the plugin manager. Then can open some xmcd files, but from the File/Open dialog, not with double clicking in the file. Best regards. Alvaro.
Joined: 23/07/2013(UTC) Posts: 1,159 Was thanked: 526 time(s) in 352 post(s)
Originally Posted by: basri Is there a way to import Mathcad file to SMath? Smath can import mathcad files natively. And there are plugins which help to import xmcd files. Yet Smath can import limited basic xmcd files. Most mathcad files won't import to smath. Anything complex (graphics, tables, etc) will fail. Try to rewrite your .xmcd files in smath as .sm. Regards
Originally Posted by: Razonar Originally Posted by: basri ... Is there a way to import Mathcad file to SMath? I tried to open it in Smath, but it did not show anything (blank page in SMath) ... Hi Basri. From the start of this thread, on Miscellaneous: "XMCD plug-in removed from the standard installer". So, you need to install it from the plugin manager. Then can open some xmcd files, but from the File/Open dialog, not with double clicking in the file. Best regards. Alvaro. Hi, Alvaro Thank you. It works. Basri
Joined: 12/02/2018(UTC) Posts: 62 Location: Belém Was thanked: 7 time(s) in 6 post(s)
Not trying to cause any fuss in here, but is there any prediction for an update of the program? I'm excited for the Writer, specially!
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,690 Location: Italy Was thanked: 1368 time(s) in 895 post(s)
Hello, Originally Posted by: joaobr Not trying to cause any fuss in here, but is there any prediction for an update of the program? I'm excited for the Writer, specially! Originally Posted by: Andrey Ivashov [...] 2) I will try to prioritize your request to release it next Month (can't guarantee, but will try).
Best regards. |
Joined: 28/11/2017(UTC) Posts: 20 Location: Pisa Was thanked: 2 time(s) in 2 post(s)
Hello everybody, I just tried to download the latest stable release and got a message of Page Not Found (HTTP 404). See image below. Any suggestion? Thanks Marco
The download link is STILL not working. @overlord link is working
Joined: 25/09/2013(UTC) Posts: 327 Location: IL Was thanked: 19 time(s) in 17 post(s)
Just curious - what is the latest update on SMath? Are there plans for future updates? Maybe you posted this elsewhere and I have not seen it.
It seems the forum has been abandoned by official SMath admin. Probably due to the fact that they partnered with a company in Israel. Probably helps sales when your company is not Russian based. The software has updated several times without a post here as was done in the past. I'm running stable 1.2.9018
The forum is also not allowing new registrations. So my guess is that it will die out or eventually be shut down, and we will have a good MathCAD competitor in all respects, including pricing. Can't blame them though, lots of free users always demanding of support, and not willing to finance the project. I've been a paying user for some time now, and I don't mind continuing to pay. The program is good, and if more people paying means better development, then I'm happy with that outcome.
Originally Posted by: RFreund what is the latest update on SMath? Changelogs: Latest version - All versionsAPI DocumentationOriginally Posted by: wb.c The forum is also not allowing new registrations. This was made by Andrey because the SPAM amount in the past week, I think it will be allowed again in some day (it happened in the past months several times). Edited by user 11 September 2024 22:56:24(UTC)
4 users thanked Davide Carpi for this useful post.
on 12/09/2024(UTC), on 12/09/2024(UTC), on 12/09/2024(UTC), on 12/09/2024(UTC)
SMath Studio Forum
