SMath Studio Forum
Samples
Using splines to find the Area Under the Curve
Joined: 28/03/2023(UTC) Posts: 26 Location: San Miguel de Tucumán Was thanked: 3 time(s) in 3 post(s)
Hi, These two examples solve the problem calculations for the total biomass formed in a batch bioreactor and the pattern flow of a reactor with a pulse of some tracer. The splines method and the Simpson integration formula found in the forum let me solve both problems. Kind regards, splines_integral_data.sm (31kb) downloaded 22 time(s). splines_integral_data1.sm (32kb) downloaded 16 time(s).
1 user thanked Javier Ochoa for this useful post.
Hello Fitting Javier's data to the Gauss function by the Levenberg-Marquardt Algorithm Javier_fit_CBG.sm (38kb) downloaded 17 time(s).Best Regards Carlos
1 user thanked CBG for this useful post.
Hi Jean and Carlos, These worksheets help me to better understand the problem which I tried to solve.
Thanks in advance,
Hi Jean and Carlos, I am curious about your thoughts for the result I found using the al_nlqsolve routine from ALGLIB. May be I was lucky to find a similar solution. Kind regards, LevenbergMarquardt_solver.sm (28kb) downloaded 12 time(s).
Originally Posted by: Javier Ochoa Hi Jean and Carlos, I am curious about your thoughts for the result I found using the al_nlqsolve routine from ALGLIB. May be I was lucky to find a similar solution. Kind regards, LevenbergMarquardt_solver.sm (28kb) downloaded 12 time(s). Hi Javier As you can see in the graph, the green line is that of your solution, and it is not correct, since it does not fit the data. It is always important to draw the curve Javier fit.sm (25kb) downloaded 7 time(s).Best Regards Carlos
Hola Javier. Your Levenberg Marquardt algorithm works pretty well, but you choose a bad guess starting point, with a very high tolerance. BTW, I made some few modifications and use also other target function. LevenbergMarquardt_solver.sm (33kb) downloaded 12 time(s). LevenbergMarquardt_solver.pdf (234kb) downloaded 10 time(s).Best regards. Alvaro.
on 24/05/2023(UTC), on 24/05/2023(UTC)
Originally Posted by: Javier Ochoa Hi, These two examples solve the problem calculations for the total biomass formed in a batch bioreactor and the pattern flow of a reactor with a pulse of some tracer. The splines method and the Simpson integration formula found in the forum let me solve both problems. Kind regards, splines_integral_data.sm (31kb) downloaded 22 time(s). splines_integral_data1.sm (32kb) downloaded 16 time(s). Hola Javier. You can also use this code for integrate and differentiate tabulated data. splines_integral_data.sm (86kb) downloaded 11 time(s). splines_integral_data.pdf (181kb) downloaded 6 time(s).Best regards. Alvaro. Edited by user 24 May 2023 21:55:06(UTC)
| Reason: Not specified
SMath Studio Forum
Samples
