Joined: 20/03/2009(UTC) Posts: 21 Location: Vienna, AUSTRIA
Hello, I tried to write a Runge-Kutta-Algorithm but I got a strange conversion type error. I've put a screenshot, the sm-File and an additional scilab-File (which shows what I was trying to do) on rapidshare. http://rapidshare.com/files/231885672/RK4.rarIt is strange because if I just calculate the equation there is no error. The error arises just when I try to allocate a variable with the equation. During this example I found a few things which might be nice to implement: 1) replace or set complete lines of a matrix (it is possible with el(), but not with row() or col() ) 2) add lines to the programming tool line() 3) define return feature to use line() within a function definition (e.g. func(x):=line(a:=3;return a*x)) 4) Button to disable/enable calculation (important if you deal with big matrices) that's all for now ancing: Ciao Jakob
Hello, Jakob. All the features you requested should be done. I'm agree. So, I'm going to work Will check error later today and will answer then. P.S.: Regarding to adding lines to the programming tool line() - it is possible to do now. Just place cursor on the left or on the right of the Line (it's actual also for Sys() and Mat()) and you will see a small Tag on the lower-right corner. Just move this Tag with a mouse or stylus to change size of the object. Here is a screen: Edited by user 12 May 2009 15:10:08(UTC)
| Reason: Not specified
"Type conversion error. Please contact the developer" error message appear when inserting a matrix as another matrix element. Actually, it is allowed to define such a matrix (like in Mathcad) but the error will apear when trying to display it. I suppose multidimensional arrayes are not implemented yet and maybe planned for some next releases. On the second thoughts, I think that just two dimensinal arrays might be just enough. Regards, Radovan P.S. I am just playing Edited by user 25 June 2009 04:11:07(UTC)
smath wrote:Just place cursor on the left or on the right of the Line (it's actual also for Sys() and Mat()) and you will see a small Tag on the lower-right corner. Just move this Tag with a mouse or stylus to change size of the object. Here is a screen: One should be careful when, say, decrease the matrix dimension. The changes will be saved by releasing the mouse button. On the other hand, Undo will get matrix back, but often the last matrix elemet - lower right element - value will be lost (the empty placeholder appear instead) Regards, Radovan |
omorr wrote:One should be careful when, say, decrease the matrix dimension. The changes will be saved by releasing the mouse button. On the other hand, Undo will get matrix back, but often the last matrix elemet - lower right element - value will be lost (the empty placeholder appear instead) Thank you for the bug reports! This one is new for me, so doublethanks! I've fixed the last one with matrix resizing and here is new build for you: SMathStudioDesktop.0_80_3463.Setup.msiIt includes really many important fixes, so, I think this version would be more interesting for you. Mathcad files parsing improved (.xmcd files), bugs fixed, numden(..) and range(..) functions added, Disable/Enable evaluation implemented via Context Menu, you can check multiple Graphs here as well and etc. Also it has Insert -> Area menuitem, but work in progress there, so it has several known bugs - just don't use it. Just one more thing - this is beta, public release version will be available later.
Thank you, I will test it of course, regarding that I am playing with it just few days - and I like it . Just one thing at the moment before I install this beta, please. I suppose there is no way in SMath yet to have a vector (single index). As we know, Mathcad consider column matrix as a vector (elements could be represented with single index). Regards, Radovan |
SMath Studio also have Vector data type (it's matrix with single column, too), but it still not have element getter with single index. I hope to find a time for this before the next release will be ready.
Thanking in advance I tried "denum" - it seems it works OK as numerical or symbolic. I had some troubles to figure out "range" (not understand it quite well from the help) but it seems it works pretty OK. As I have the comma as a decimal separator (Serbian regional settings) I am very satisfied that it works too. I tried this an it works Ok 1..10 1;3..9 -1;-3..-15 etc. I did not know how to put multiple charts in one 2D plot and I guessed that Equation systems template might work. I was right and I could plot equations in x, user defined functions, two column matrix ... I suppose that some additional plot configuration and control will be implemented when you have the time. As I understood the chart colors are automatically selected, and the charts could be lines or dots at the moment. Am I right? I've noted one thing also. When the plot is selected, and the option "Select all" is chosen by right click button, the word SELLECTALL will appear in the place of the editing line inside the graphics. BTW, I like the system of using the mouse in 2D plots (moving, zooming...). I even do not know if Mathcad had ever had such a feature. Regards, Radovan |
omorr wrote:When the plot is selected, and the option "Select all" is chosen by right click button, the word SELLECTALL will appear in the place of the editing line inside the graphics. Reproduced, will fix. Thank you. One more thing: this beta already has ability to work with two different for(..) functions, with 3 and 4 arguments. Here an example I've prepared: Open in SMath Cloud
Very good! By the way, how did you do that? Whatever I done it always brings the Mathcad like for loop (three arguments). I managed once somehow to get the C style (four arguments) but did not pay attention how? Choosing from the template, or Inserting - function will always give Mathcad like for loop, although in the Inserting Function, Example field the C style remained. Even if I try to put "for(" after the second argument it brings me back to the Mathcad style. EDIT: I fugured out! Put the second argument say k<5 and after that ; will give C style foor loop Edited by user 25 June 2009 19:28:29(UTC)
You just need to press on the functions argument delimiter button one more time and SMath Studio will redraw for expression to C style. - For function with 1 arg:
for(#)
- For function with 2 args:
for(#;#)
- For function with 3 args:
for(#;#;#)
- For function with 4 args:
for(#;#;#;#)
- For function with 5 args:
for(#;#;#;#;#)
Functions with 1, 2 or 5 and more arguments can be used as user defined. Same stuff with diff(..) and range(..) functions. This logic goes throw the whole program...
Thank you, I understand it now.
Regards, Radovan |
