3 Pages<123>
Offline kilele
#21 Posted : 05 October 2012 20:08:24(UTC)
kilele
Originally Posted by: omorr Go to Quoted Post
To be honest, in order to replace Mathcad (Prime) and use SMath completely in my teaching, I need only few more things (like nonlinear curve fitting) but time is passing and I am still waiting Wonder . I have enough time for that, but would like to be ASAP.
It is easily to find out that these few things are needed for majority of the engineering math and modeling problems. SMath's visual capabilities are very attractive for engineering applications.
- system of linear equations (SMath - should be improved)
- system of nonlinear equations (SMath - roots(), not good enough - plugin made by w3b5urf3r)
- system of first order ODE (SMath - plugin made by uni, improving appreciated)
- interpolation (SMath - included, should be improved)
- differentiation, integration (SMath - should be improved)
- linear and nonlinear curve fitting (SMath - not included, neither plugins made)
- 2D and 3D plotting (SMath - should be improved)
- units (SMath - quite good enough)
Hi omorr, this is a useful reference for Andrey and plugin developers.
Could you elaborate more each section ? by specifying which features should be added/improved/corrected.
Offline omorr
#22 Posted : 05 October 2012 20:56:02(UTC)
omorr
Serbia
Hello kilele,
I hope you would not mind, but I suggest you to search the Forum and to see some of my posts. As you could see, there are almost one thousand of them (I sometimes hesitate to post because of being annoying with so many of them). Whatever I would write here, would be repeating the things I already mentioned. By the way, you also mentioned and posted many links to numerical algorithms and methods Good . I respect any developer who is willing to put all those methods and keep them "alive" in SMath, but eventually it will take quite a long time.
Actually, the priorities in SMath development are up to the Andrey's decisions and he knows the best about it.
Offline uni
#23 Posted : 06 October 2012 09:01:19(UTC)
uni
I updated the plugin now works more stable.
File Attachment(s):
Draghilev's method. NLS. Example 2.smz (7kb) downloaded 66 time(s).
uni attached the following image(s):
Russia ☭ forever
Viacheslav N. Mezentsev
on 06/10/2012(UTC)
Offline omorr
#24 Posted : 06 October 2012 09:24:32(UTC)
omorr
Serbia
You are right uni, thank you Good
Now, every F9 produces result for your test problem.
Offline uni
#25 Posted : 06 October 2012 17:06:38(UTC)
uni
20 points (~24 sec). I made some little changes in Draghilev() function.
File Attachment(s):
Draghilev's method. NLS. Example 2.smz (7kb) downloaded 59 time(s).
Russia ☭ forever
on 06/10/2012(UTC)
Offline omorr
#26 Posted : 06 October 2012 18:02:10(UTC)
omorr
Serbia
Hello uni,
It is quite interesting that you've made it working with 20 points Good .
By the way, I've added the sum of squares - just to check how this sum reduces its value.
on 06/10/2012(UTC)
Offline uni
#27 Posted : 06 October 2012 18:17:30(UTC)
uni
Yes, but initial value for a is X0 := stack(1, 1, 1, 1) Umnik Wink
Edited by user 06 October 2012 18:22:31(UTC)  | Reason: Not specified
Russia ☭ forever
Offline omorr
#28 Posted : 06 October 2012 19:20:33(UTC)
omorr
Serbia
Sorry, uni, my mistake Blush. Graph distracted me Blush
In this example - this is really amazing Shok
If this could work for a bit more complicates functions - it would be really great Good .
Edited by user 06 October 2012 19:24:34(UTC)  | Reason: Not specified
on 07/10/2012(UTC)
Offline kilele
#29 Posted : 07 October 2012 01:58:38(UTC)
kilele
By the way, I bumped many times into the derivative, gradient, Jacobian problem in SMath and almost always had to give it up. I even asked Andrey few times to introduce numerical differentiation in spite of the well known fact that numerical differentiation is prone to numerical errors. Calculating even derivatives (Jacobian is another nightmare) analytically is sometimes almost impossible and there is no other way than using some kind of numerical approximation. Therefore, when Jacobian is involved in some calculation - I always find myself unconfortable Blush Hysterics
Please look at these matlab algorithms:
See pdfpage 112/docpage 90 of this document for a jacobian approximation by finite difference
http://www.dsic.upv.es/d...92/TesisEnriqueArias.pdf
Adaptive Robust Numerical Differentiation (matlab code)
http://www.mathworks.com...umerical-differentiation
Offline uni
#30 Posted : 07 October 2012 10:49:42(UTC)
uni
Quote:
Thank you for considering this Good . If you include the sum of squares to your example above, then it is equivalent as finding the roots of this three equations
sum(((el(pp,i)-f(el(xx,i),a1,a2,a3))*diff((f(el(xx,i),a1,a2,a3)),a1)),i,1,n)≡0
sum(((el(pp,i)-f(el(xx,i),a1,a2,a3))*diff((f(el(xx,i),a1,a2,a3)),a2)),i,1,n)≡0
sum(((el(pp,i)-f(el(xx,i),a1,a2,a3))*diff((f(el(xx,i),a1,a2,a3)),a3)),i,1,n)≡0
It is a well known and maybe redundant to say, sorry - the first derivatives over three unknowns (a1,a2,a3) should be zero
Now I knew where it came from. I also fixed a bug with double index ii. I've used it twice.
File Attachment(s):
Draghilev's method. NLS. Example 2.1.smz (7kb) downloaded 59 time(s).
Russia ☭ forever
Offline omorr
#31 Posted : 07 October 2012 13:20:29(UTC)
omorr
Serbia
Hello uni,
It seems very promising Good
As it is basically a linear regression over parameters (polynomial equation) I just added the result of it - just for checking. The results are very close to each other. It is interesting that the method is working on this problem very well Good
The determinant det((transpose(XX)*XX))=2.40082615642816*10^16is rather far from zero - well conditioned system. I suppose that would be very interesting to see what will happen when this determinant is quite close to zero - ill conditioned system. I suppose that the results must be quite different.
File Attachment(s):
Draghilev's method. NLS. Example 2.1-omorr.sm (46kb) downloaded 55 time(s).
on 07/10/2012(UTC)
Offline uni
#32 Posted : 07 October 2012 13:34:11(UTC)
uni
Yes, it would be interesting. I'll try to find an example. To improve accuracy, we can increase the parameter N. As for the more complex functions, I'm working on it.
Russia ☭ forever
on 07/10/2012(UTC)
Offline omorr
#33 Posted : 07 October 2012 14:25:11(UTC)
omorr
Serbia
Hello kilele,
Thank you for the links. Actually, that is the point. At the moment, many plugins which rely on symbolic derivative, gradient, Jacobian, Hessian have great chance to fail sometimes due to the SMath symbolic restrictions and features or simply due to a complicated expressions obtained. There were many situations when you can actually have the numerical values of a vector valued function, but you can not have the derivatives of its elements (therefore, can not calculate Jacobian, Hessian etd.) and every method who use this will also fail (take a look for instance at the efforts of w3b5urf3r an the Nonlinear-solvers plugin). We can actually make Jacobian function ourselves (like the one very simple and hardly useful as in the attached example), but I think that is not the point. Numerical derivation methods are quite prone to errors and I would very like that someone make a plugin (based on some more sophisticated algorithms) like the one mentioned in your second link.
Edited by user 07 October 2012 14:31:21(UTC)  | Reason: Not specified
File Attachment(s):
Jacnum.sm (17kb) downloaded 54 time(s).
Offline uni
#34 Posted : 08 October 2012 12:42:03(UTC)
uni
Radovan, it's really hard to get a solution using the Draghilev method. I do not know how to do it yet.
The solution here is: [28.4502559095434933, -2720.12633981294994, -7.01208324395984839]. Maybe later I'll be able to get it.
Russia ☭ forever
on 08/10/2012(UTC),  on 09/10/2012(UTC)
Offline omorr
#35 Posted : 08 October 2012 15:01:52(UTC)
omorr
Serbia
Do not worry about it uni Good ,
I think it is good enough that you solved many other examples including this particular problem Thank you .
Edited by user 08 October 2012 15:03:52(UTC)  | Reason: Not specified
on 08/10/2012(UTC)
Offline алексей_алексей
#36 Posted : 08 October 2012 15:38:37(UTC)
алексей_алексей
Was thanked: 13 time(s) in 8 post(s)
Experience shows that the Draghilev's method is most effective when searching for an infinite set of solutions, when f1 ... fm, x1 ... xn and n>m ...
... not worry... uni Good ,
Be happy.
thanks 2 users thanked алексей_алексей for this useful post.
on 08/10/2012(UTC),  on 08/10/2012(UTC)
Offline uni
#37 Posted : 09 October 2012 09:48:33(UTC)
uni
Example 2. Finding roots: System 1 (Mathcad 15)
sys(x^2-y*x+y^2-1=0;sin(5*x^2)+sin(4*y^2)=0;2;1)
Edited by user 09 October 2012 09:52:27(UTC)  | Reason: Not specified
File Attachment(s):
Russia ☭ forever
on 09/10/2012(UTC),  on 09/10/2012(UTC)
Offline uni
#38 Posted : 11 October 2012 08:01:39(UTC)
uni
Example 5. Finding roots: System 4.
sys(x^2+y^2-8=0;sin(x*y)*sin(exp(x*y))=0;2;1)
I made minor changes to simplify the calculations. Function has become more clear.
Calculation time: ~1.5 min
Roots: 80
File Attachment(s):
Draghilev's method. Finding roots. System 4.pdf (113kb) downloaded 61 time(s).
Draghilev's method. Finding roots. System 4.smz (115kb) downloaded 81 time(s).
Russia ☭ forever
on 11/10/2012(UTC)
#39 Posted : 11 October 2012 09:13:05(UTC)
алексей_алексей
x1^3+x2^3-0.1e-1*sin(1.0001*x1+x2)=0;
One equation with two unknowns or implicitly given function. In the figure we can see the points at which violated the conditions of existence of an implicit function.
Draghilev's method.
x1 and x2 are solutions of this equation and are functions of the arc length, which allows a clear move along places where there are no implicit function in the classically accepted terms …
Offline uni
#40 Posted : 22 October 2018 23:14:47(UTC)
uni
Examples updated.
Draghilev's method. Finding roots. System 0.sm (349kb) downloaded 29 time(s).
Draghilev's method. Finding roots. System 0.pdf (317kb) downloaded 34 time(s).
Draghilev's method. Finding roots. System 1.sm (325kb) downloaded 31 time(s).
Draghilev's method. Finding roots. System 1.pdf (330kb) downloaded 29 time(s).
Draghilev's method. Finding roots. System 2.sm (30kb) downloaded 28 time(s).
Draghilev's method. Finding roots. System 2.pdf (92kb) downloaded 28 time(s).
Draghilev's method. Finding roots. System 3.sm (307kb) downloaded 27 time(s).
Draghilev's method. Finding roots. System 3.pdf (307kb) downloaded 27 time(s).
Draghilev's method. Finding roots. System 4.sm (70kb) downloaded 28 time(s).
Draghilev's method. Finding roots. System 4.pdf (161kb) downloaded 28 time(s).
Russia ☭ forever
on 23/10/2018(UTC),  on 23/10/2018(UTC)
Guest (2)
3 Pages<123>
