Joined: 04/07/2015(UTC) Posts: 6,866  Was thanked: 983 time(s) in 811 post(s)
Originally Posted by: overlord  Result can not be parsed through plugin Check for more, but not possible to exhaust. Maple Sanity.sm (61kb) downloaded 57 time(s).
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,640   Was thanked: 1400 time(s) in 817 post(s)
Originally Posted by: overlord  It works now but with a small issue. Tried with both optimizations but cannot jump over this issue. Result can not be parsed through plugin if nthroot is nested. When it is written as power it can be calculated however. I need to rewrite part of the function for this. I can't fix it quickly yet. |
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
Joined: 23/07/2013(UTC) Posts: 1,192  Was thanked: 545 time(s) in 367 post(s)
Originally Posted by: uni  I need to rewrite part of the function for this. I can't fix it quickly yet.
Doesn't matter when as long as it is fixed. Well, if you say I won't fix ever or any time soon I respect that too. Thanks. Edited by user 07 March 2021 12:51:07(UTC)
| Reason: Not specified
A simple function to correct maple plugin result matrix. Regards maplecorrect.sm (27kb) downloaded 77 time(s).
 2 users thanked overlord for this useful post.
on 03/03/2022(UTC), on 22/03/2022(UTC)
 Plugin updated. Changes: - maple() returns the string as is without conversion; - refactored.  maple-system.sm (10kb) downloaded 27 time(s). |
More simple. Regions with a red border still work.  maple-system-2.sm (9kb) downloaded 13 time(s). |
Joined: 28/08/2014(UTC) Posts: 1,513  Was thanked: 976 time(s) in 610 post(s)
Originally Posted by: uni  More simple. ... An small variation.
maple-system-4'.sm (12kb) downloaded 17 time(s).Best regards. Alvaro.
Small restrictions. All curly braces are converted. This is necessary for the maple() function to work. I'll see if it's possible to make an exception for strings.  maple-system-5.sm (13kb) downloaded 14 time(s). |
Joined: 27/03/2019(UTC) Posts: 77  Location: coah Was thanked: 28 time(s) in 23 post(s)
I only get this...may be problems with the permission?  if i change de path...  some advices? Edited by moderator 24 April 2023 15:31:31(UTC)
The path "D:\Temp" must exists. |
I hope you can solve the problem with the {} for now this format works for combined text and number output.
Originally Posted by: uni  The path "D:\Temp" must exists. yes, this work very well, thanks!
 Plugin updated. Changes: - added support for SMath variables; - curly brackets in strings are not replaced.  maple-system-5.sm (14kb) downloaded 20 time(s).Edited by user 27 April 2023 09:07:54(UTC)
Originally Posted by: uni  More simple ... But powerful. For install SymPy on windows can use " pip install sympy" or " conda install sympy" in a DOS shell window.  Best regards. Alvaro.
Same for R. You can install it using scoop: scoop install R maple-system-R.sm (9kb) downloaded 10 time(s). |
Hi uni, Me again complaining about Linux. After changing file paths according to linux, your new features can create test.py and out.txt. But out.txt is empty. Changing python command to /usr/bin/python didn't work either. If there is a trick to make it work under linux, it would be useful.
