Offline adiaz
#1 Posted : 02 October 2012 08:13:52(UTC)
adiaz
Rank: Member
Was thanked: 5 time(s) in 5 post(s)
Hessian example.
File Attachment(s):
Hessian.sm (12kb) downloaded 72 time(s).
adiaz attached the following image(s):
thanks 1 user thanked adiaz for this useful post.
on 02/10/2012(UTC)
Offline uni
#2 Posted : 02 October 2012 09:27:02(UTC)
uni
Biggrin
Russia ☭ forever
Viacheslav N. Mezentsev
on 02/10/2012(UTC)
Offline adiaz
#3 Posted : 02 October 2012 10:16:45(UTC)
adiaz
Rank: Member
Check this.
Offline uni
#4 Posted : 02 October 2012 10:36:06(UTC)
uni
It is not a good idea to use smath subscripts in maple. Here I need to think a little bit.
uni attached the following image(s):
Russia ☭ forever
Offline adiaz
#5 Posted : 02 October 2012 11:35:18(UTC)
adiaz
Rank: Member
Nice bug. This a workaround.
Offline adiaz
#6 Posted : 06 October 2012 10:17:29(UTC)
adiaz
Rank: Member
I think that this is the better way to work with the Jacobian.
File Attachment(s):
Jacobian.sm (23kb) downloaded 75 time(s).
Offline omorr
#7 Posted : 06 October 2012 14:24:02(UTC)
omorr
Serbia
Hello Alvaro,
But what to do if the vector function is defined this way?
Φ(X,t):-5*t*mat(el(X,1),el(X,2),2,1)+mat(el(X,2)*el(X,1)^2,el(X,2)^2*el(X,1)^2,2,1)
It will not work until t is a constant (scalar). Take a look at the pictures please.
Edited by user 06 October 2012 14:39:44(UTC)  | Reason: Not specified
Offline adiaz
#8 Posted : 06 October 2012 22:26:35(UTC)
adiaz
Rank: Member
What doesn´t works is length, so can't include symbolic scalars outside vectors.
Regards.
Offline omorr
#9 Posted : 07 October 2012 09:40:21(UTC)
omorr
Serbia
Hello Alvaro,
Actually, that is the point. I think that's the problem of the symbolic engine.
The first one gives the symbolic result
(-5*t)*mat(el(X,1),el(X,2),2,1)+mat(el(X,2)*el(X,1)^2,el(X,2)^2*el(X,1),2,1)=mat(-5*el(X,1),-5*el(X,2),2,1)*t+mat(el(X,2)*el(X,1)^2,el(X,2)^2*el(X,1),2,1)
and the result is not a vector, therefore length() does not work.
The second one actually give you the vector symbolically
(-5)*mat(el(X,1)*t,el(X,2)*t,2,1)+mat(el(X,2)*el(X,1)^2,el(X,2)^2*el(X,1),2,1)=mat(el(X,1)*(-5*t+el(X,2)*el(X,1)),el(X,2)*(-5*t+el(X,2)*el(X,1)),2,1)
Maybe the solution would be to say in advance what the variable t was - either scalar, vector or matrix. Something like "assume". If SMath assumed that t was a scalar, it should behave in accordance to that and give you the second correct result.
