Hi
i have try now couple of different option "crossover" "parallels" but first all of them are buggy and wasting storage and Memory, I come from Windows and figure out that I miss a lot of my daily software but the smoothness of macOS let me windows complete forgot. BUUUUTTTT again its triggers my brain to use crossover or any else virtual environment for this software.
maybe some one have a good solution to me
thanks to the devs I love your work!
Joined: 23/07/2013(UTC) Posts: 1,126 Was thanked: 507 time(s) in 338 post(s)
Originally Posted by: overlord Brew already installed. Mono i have removed after i get smath not running. but i will try later again maybe i make something wrong thanks again!!!
Originally Posted by: overlord hi I get this error Code:mono SMathStudio_Desktop.exe
╭─marco at MacBook Air von Marco in ~/Downloads/SMathStudioDesktop.1_0_8348.Mono
╰─○ WARNING: The Carbon driver has not been ported to 64bits, and very few parts of Windows.Forms will work properly, or at all
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.dylib assembly:<unknown assembly> type:<unknown type> member:(null)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000b0] in <7732fab08a2e4a3a87ced52968a7dd68>:0
--- End of inner exception stack trace ---
at System.Drawing.StringFormat..ctor (System.Drawing.StringFormatFlags options, System.Int32 language) [0x00011] in <7732fab08a2e4a3a87ced52968a7dd68>:0
at System.Drawing.StringFormat..ctor () [0x00000] in <7732fab08a2e4a3a87ced52968a7dd68>:0
at (wrapper remoting-invoke-with-check) System.Drawing.StringFormat..ctor()
at System.Windows.Forms.ThemeWin32Classic.ResetDefaults () [0x0001f] in <7ce885104bdc464983c0cd22621454da>:0
at System.Windows.Forms.ThemeVisualStyles.ResetDefaults () [0x00000] in <7ce885104bdc464983c0cd22621454da>:0
at System.Windows.Forms.ThemeWin32Classic..ctor () [0x00006] in <7ce885104bdc464983c0cd22621454da>:0
at System.Windows.Forms.ThemeVisualStyles..ctor () [0x00000] in <7ce885104bdc464983c0cd22621454da>:0
at System.Windows.Forms.ThemeEngine..cctor () [0x00007] in <7ce885104bdc464983c0cd22621454da>:0
at System.Drawing.FontFamily..ctor (System.Drawing.Text.GenericFontFamilies genericFamily) [0x00041] in <7732fab08a2e4a3a87ced52968a7dd68>:0
at (wrapper remoting-invoke-with-check) System.Drawing.FontFamily..ctor(System.Drawing.Text.GenericFontFamilies)
at System.Drawing.FontFamily.get_GenericMonospace () [0x00000] in <7732fab08a2e4a3a87ced52968a7dd68>:0
at SMath.Environment.DesktopSystemSpecifics..ctor () [0x0000d] in <adceaf0c68aa445fbe598ba702a8fefe>:0
at SMath.Environment.SessionsManagerPaths..ctor (System.String[] resourcesPaths) [0x00000] in <adceaf0c68aa445fbe598ba702a8fefe>:0
at SMath.Environment.SessionsManagerPaths.Create (System.String[] paths) [0x00012] in <adceaf0c68aa445fbe598ba702a8fefe>:0
at SMath.Environment.AppSettingsDesktop.Initialize (SMath.Manager.PluginsStatusEventHandler loaded) [0x0005e] in <adceaf0c68aa445fbe598ba702a8fefe>:0
at .. (System.String[] ) [0x00043] in <303e7d1bbb444cb4b506d9c12f946d28>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.dylib assembly:<unknown assembly> type:<unknown type> member:(null)
this come if I double click smathstudo_desktop_mono Code:╭─marco at MacBook Air von Marco in ~
╰─○ /Users/marco/Downloads/SMathStudioDesktop.1_0_8348.Mono/smathstudio_desktop_mono ; exit;
Cannot open assembly './SMathStudio_Desktop.exe': No such file or directory.
Saving session...completed.
[Prozess beendet]
Edited by user 09 February 2023 23:07:15(UTC)
| Reason: Not specified
after google search i foul d this https://lemp.io/how-to-install-mono-on-mac-os/Quote:Add Mono To Path Mac
Adding mono to your path on a Mac is a pretty simple process. Just open up your Terminal and type in the following command: export PATH=/Library/Frameworks/Mono.framework/Versions/Current/bin:$PATH This will add the mono binaries to your path, allowing you to easily use them from the command line. and I get new error message : Code:
╰─○ mono SMathStudio_Desktop.exe
Native Crash Reporting
Got a segv while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Native stacktrace:
0x1004f8639 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_dump_native_crash_info
0x1004903ee - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_handle_native_crash
0x1004f27b6 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : altstack_handle_and_restore
0x7ff8153c97f5 - /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight : SLDisplayBounds
0x110b7fbf8 - Unknown
0x109449ba6 - Unknown
0x1003ed332 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_runtime_invoke
0x1005fe7b2 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_try_invoke
0x1005fd3d8 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_class_init_full
0x1003e4d3c - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_compile_method_inner
0x1003e888a - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_compile_method_with_opt
0x100492f0e - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : common_call_trampoline
0x100492950 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_magic_trampoline
0x109415393 - Unknown
0x10c4c555b - Unknown
0x110387b58 - Unknown
0x10b6dcb23 - Unknown
0x10cb0ec23 - /Library/Frameworks/Mono.framework/Versions/6.12.0/lib/mono/4.5/mscorlib.dll.dylib : System_Threading_ExecutionContext_Run_System_Threading_ExecutionContext_System_Threading_ContextCallback_object_bool
0x1005fcdd7 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_invoke_checked
0x1006036d0 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_delegate_try_invoke
0x100627c5d - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : start_wrapper
0x7ff810501259 - /usr/lib/system/libsystem_pthread.dylib : _pthread_start
0x7ff8104fcc7b - /usr/lib/system/libsystem_pthread.dylib : thread_start
Telemetry Dumper:
Pkilling 0x12971433984x from 0x12974649344x
Pkilling 0x8602342080x from 0x12974649344x
Entering thread summarizer pause from 0x12974649344x
Finished thread summarizer pause from 0x12974649344x.
Failed to create breadcrumb file (null)/crash_hash_0x7d0fddfc2
Waiting for dumping threads to resume
External Debugger Dump:
Basic Fault Address Reporting
Memory around native instruction pointer (0x7ff8153c97f5):0x7ff8153c97e5 89 fb 48 8b 05 0a 6b bc 3c 0f 10 00 0f 10 48 10 ..H...k.<.....H.
0x7ff8153c97f5 0f 11 4f 10 0f 11 07 89 f7 48 89 de e8 58 3b fa ..O......H...X;.
0x7ff8153c9805 ff 48 89 d8 48 83 c4 08 5b 5d c3 55 48 89 e5 53 .H..H...[].UH..S
0x7ff8153c9815 48 83 ec 28 48 8b 05 b8 76 bb 3c 48 8b 00 48 89 H..(H...v.<H..H.
Managed Stacktrace:
at <unknown> <0xffffffff>
at System.Windows.Forms.XplatUICarbon:CGDisplayBounds <0x000b7>
at System.Windows.Forms.XplatUICarbon:get_WorkingArea <0x00072>
at System.Windows.Forms.XplatUICarbon:get_VirtualScreen <0x00043>
at System.Windows.Forms.XplatUI:get_VirtualScreen <0x00048>
at System.Windows.Forms.Screen:.cctor <0x0017a>
at System.Object:runtime_invoke_void <0x000a5>
at System.Windows.Forms.Form:get_CreateParams <0x0062a>
at System.Windows.Forms.Form:SetClientSizeCore <0x001c7>
at System.Windows.Forms.Control:set_ClientSize <0x00048>
at System.Windows.Forms.Form:set_ClientSize <0x00052>
at System.Windows.Forms.Form:UpdateWindowText <0x00082>
at System.Windows.Forms.Control:set_Text <0x000ac>
at System.Windows.Forms.Form:set_Text <0x0004a>
at SMath.UI.Accessories.SplashScreen:.ctor <0x009b8>
at SMath.UI.Accessories.SplashScreen:.ctor <0x00072>
at SMath.UI.Accessories.SplashScreen: <0x0009a>
at System.Threading.ThreadHelper:ThreadStart_Context <0x000e1>
at System.Threading.ExecutionContext:RunInternal <0x001a9>
at System.Threading.ExecutionContext:Run <0x00042>
at System.Threading.ExecutionContext:Run <0x00067>
at System.Threading.ThreadHelper:ThreadStart <0x0006a>
at <Module>:runtime_invoke_void__this___object <0x000c3>
error mono smath.txt (52kb) downloaded 1 time(s).
I think the Windows operating system is better than the Mac for various reasons. It offers more customization options, has a wider range of software, and is more cost-effective. To use all the Windows features, you can check out the reddit windows keys. They offer a variety of keys at a great price, so you can get the most out of your Windows computer. The licensed version works much better, moreover, you get timely access to updates. Edited by user 13 February 2023 13:37:56(UTC)
Originally Posted by: DylanMendos I think the Windows operating system is better than the Mac for various reasons. You answer is so much useless as your complete l… Windows and all pc on the world can never run so good as macOS on an apple silicon chip. I grow up with windows I can fix on windows every problem. And to talk to you is so worst useless for me. And we can see that the creator have no idea to fix it!
