26 Pages«<23242526>
Offline overlord
#481 Posted : 29 July 2022 02:23:20(UTC)
Turkey
Was thanked: 444 time(s) in 298 post(s)
Originally Posted by: uni Go to Quoted Post
If you sometimes see a similar problem, then this is an error in the operation of a parallel algorithm used to speed up data processing.
Are these indecent lines result for same kind of problem?
It doesn't matter when cases() used by the way, same issue.
Offline uni
#482 Posted : 29 July 2022 07:15:11(UTC)
uni
Was thanked: 1243 time(s) in 724 post(s)
No, this problem is related to the drawing algorithm. This algorithm skips points that cannot be drawn. It doesn't always work correctly at the end of lines. I am aware of this and have not yet found the time to rewrite the algorithm to be more universal.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline marks2c
#483 Posted : 17 December 2022 07:18:38(UTC)
marks2c
New Zealand
Was thanked: 4 time(s) in 3 post(s)
I'm really enjoying the ability to use XY plots to visualize parametric drawings (ie polygons, poly lines etc). Great work Uni et al.
However, I don't understand:
1. Why does a vector line matrix needs to be contained within a 1x1 matrix? I'm guessing that is the answer: ie it needs to be 1 element to be parsed. Is that correct?
2. How do you create fill? For example, green fill between the points (0,0), (1,0), (1,1) and (0,1)?
Thanks!
Offline mkraska
#484 Posted : 17 December 2022 18:40:55(UTC)
mkraska
Was thanked: 1060 time(s) in 677 post(s)
The pre-defined objects in the XY-Plot-plugin might help.
on 17/12/2022(UTC)
Offline marks2c
#485 Posted : 17 December 2022 21:22:56(UTC)
marks2c
New Zealand
Thank you both. Martin: is there a place were the available pre-defined objects are documented?
I'm doing something wrong:
Click to enlarge
Not Working.sm (6kb) downloaded 3 time(s).
Edited by moderator 20 December 2022 11:19:04(UTC)  | Reason: Not specified
Offline overlord
#486 Posted : 18 December 2022 00:16:50(UTC)
Turkey
Rename your matrix point to points.
on 18/12/2022(UTC)
Offline marks2c
#487 Posted : 18 December 2022 01:08:50(UTC)
marks2c
New Zealand
PBKAC! Thanks overlord.
Is there a list/documentation somewhere of the built-in objects?
Edited by user 18 December 2022 01:35:41(UTC)  | Reason: Not specified
Offline mkraska
#488 Posted : 18 December 2022 01:56:02(UTC)
mkraska
Section 8.3.4 in the german handbook.
Or have a look at the interactive handbook: Graphics> 2D plots (plugin X-Y Plot)
Also, have a look at the topic starter post of this thread, there is extensive documentation on this plugin.
on 18/12/2022(UTC)
Offline marks2c
#489 Posted : 18 December 2022 03:21:06(UTC)
marks2c
New Zealand
The interactive handbook (tools-plugins-interactive handbook) was most helpful.
An excellent reference. Thank you Martin.
Offline marks2c
#490 Posted : 31 January 2023 05:35:55(UTC)
marks2c
New Zealand
XYPlot: Plot Polygons: Complex Number Column Vectors
I'm hoping to plot polygons with complex number vertices as the coordinate pairs: ie x-coordinate = the real part, and y-coordinate = the imaginary part.
Is that possible? If not, would native handling of complex numbers as coordinate pairs by XYPlot be useful?
I've looked at both section 8.3.4 of the German handbook and also the Tools>Plugins>Interactive Handbooks>Interactive SMath Handbook>Graphics>2D Plots>X-Y Plot and can't find anything regarding complex number handling.
This kind of thing:
Click to enlarge
20230131 Triangle Test Complex XYPlot.sm (103kb) downloaded 3 time(s).
Thank you!
Edited by moderator 31 January 2023 17:13:56(UTC)  | Reason: Not specified
Offline Razonar
#491 Posted : 31 January 2023 07:46:51(UTC)
Razonar
Uruguay
Was thanked: 732 time(s) in 464 post(s)
XYPlot: Plot Polygons: Complex Number Column Vectors ...
Hi. This could be an option.
20230131 Triangle Test Complex XYPlot.sm (107kb) downloaded 18 time(s).
thanks 4 users thanked Razonar for this useful post.
on 31/01/2023(UTC),  on 31/01/2023(UTC),  on 31/01/2023(UTC),  on 31/01/2023(UTC)
Offline uni
#492 Posted : 01 February 2023 15:53:35(UTC)
uni
It can be done, but I doubt that it is necessary. Can you give an example where such an interpretation of complex numbers is used? I mean famous mathematical applications.
Russia ☭ forever
on 02/02/2023(UTC)
Offline marks2c
#493 Posted : 02 February 2023 06:49:26(UTC)
marks2c
New Zealand
Thanks Uni.
No sorry, I'm just an engineer.
Stuff I'd use it for are:
* Visualsation of complex impedances (eg RF matching, filters, branching etc), and
* 2D visualisation (eg polygons for estimation of state).
Offline Razonar
#494 Posted : 19 February 2023 12:09:56(UTC)
Razonar
Uruguay
Functions for grids, meshes and plot surfaces. Support triangular meshes and multiple surfaces in the same plot.
pSurf.sm (316kb) downloaded 58 time(s).
pSurf.pdf (2,254kb) downloaded 46 time(s).
thanks 3 users thanked Razonar for this useful post.
on 19/02/2023(UTC),  on 19/02/2023(UTC),  on 20/02/2023(UTC)
Offline Lupus the Canine
#495 Posted : 03 July 2023 01:07:41(UTC)
Lupus the Canine
Poland
Hi would it be possible to add an option to make splot square or have arbitrary X/Y proportion?
It would make making plots that are supposed to be proportional much easier.
For example keeping this drawing square would be much easier:
Offline overlord
#496 Posted : 03 July 2023 03:44:16(UTC)
Turkey
If I understood you correct, this option already exist.
Try to scroll with control or shift key pressed. This will either change X or Y scale depending the key used.
#497 Posted : 03 July 2023 12:52:00(UTC)
Was thanked: 961 time(s) in 789 post(s)
Hi would it be possible to add an option to make splot square or have arbitrary X/Y proportion ?
You can use the square plot technique on either or both direction
Tabulate X & Y ... (X*a)±b,,,(Y*c)±d
Offline overlord
#498 Posted : 03 July 2023 16:38:29(UTC)
Turkey
Here your functions plotted to square region.
#499 Posted : 07 July 2023 02:03:17(UTC)
Lupus the Canine
Poland
My bad, what I need is to have the grid be square not the entire plot.
I want the drawing to be proportional.
Offline Razonar
#500 Posted : 07 July 2023 19:44:59(UTC)
Razonar
Uruguay
Hi. Double clicking on the plot, you can access to the grid options for changing the 'Tick' value.
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
26 Pages«<23242526>
