Offline Thomy
#1 Posted : 27 January 2023 14:51:24(UTC)
Thomy
I can't find the error. I want to solve a simple linear equation for a static problem. But with the solve() function i can't enter units. Problem.JPG
it says not real roots.
Thanks for help
#2 Posted : 27 January 2023 17:19:01(UTC)
Originally Posted by: Thomy Go to Quoted Post
I can't find the error. I want to solve a simple linear equation for a static problem. But with the solve() function I can't enter units.
Generally, solve blocs aren't units compatible.
Attach the document for possible doctoring.
Offline Thomy
#3 Posted : 27 January 2023 18:11:37(UTC)
Thomy
Hello
You can find the file in the attachment
Offline Razonar
#4 Posted : 27 January 2023 18:27:22(UTC)
Razonar
Uruguay
There is no "solve block" there. For the real ones there is a plugin. In any case, there is a function to find roots, which is compatible with the use of units, you just have to know how to use it and in what cases. For this function, the roots function seems more suitable instead of solve. Try with this, for example
Offline Thomy
#5 Posted : 27 January 2023 18:39:17(UTC)
Thomy
Doesn't work. The File is in the attatchment.
Thanks you very much
Offline Razonar
#6 Posted : 27 January 2023 18:55:43(UTC)
Razonar
Uruguay
Doesn't work. The File is in the attachment. ...
Hi. I can't find the file.
Offline Thomy
#7 Posted : 27 January 2023 19:00:31(UTC)
Thomy
Fixpunkte LIWA.sm (4,343kb) downloaded 16 time(s).
Offline Razonar
#8 Posted : 27 January 2023 19:04:41(UTC)
Razonar
Uruguay
Hi. It works in my environment. Try with F9 for update the calculation.
#9 Posted : 27 January 2023 20:37:16(UTC)
NO file attached !!!
Offline mkraska
#10 Posted : 28 January 2023 01:20:52(UTC)
mkraska
In your initial post, just replace solve() by Solve(). This requires the Maxima Plugin being installed.
It is a symbolic solver, which has generic unit handling, i.e. the unit of the result is determined by the solver.
An alternative is the FindRoot function, where you have to provide an initial guess (starting point for the numeric solver) and the result is automatically assigned to the variable.
The maxima solver returns an equation variable=solution, which can be converted into an assignment by the Assign() function. More details to be found in the handbook (Google SMath Handbuch).
Offline Thomy
#11 Posted : 03 February 2023 18:27:57(UTC)
Thomy
How can i install the MaximaPlugin. Do i have to integrate the maxima folder in the plugin subfolder from SMath?
Offline mkraska
#12 Posted : 03 February 2023 21:20:16(UTC)
mkraska
Follow the link in my signature (points to the wiki). There you find instructions.
