Offline alisin
#1 Posted : 19 January 2023 02:57:31(UTC)
alisin
Hello!
Brand new to SMath, and I was curious to know if there was a way to simulate creating objects with properties etc. For example, I have a car object that has a speed it's moving at and its weight.
Offline Razonar
#2 Posted : 19 January 2023 03:35:14(UTC)
Razonar
Uruguay
Was thanked: 796 time(s) in 504 post(s)
Hi. Something like this?
obj_set_get.sm (12kb) downloaded 34 time(s).
on 19/01/2023(UTC),  on 20/01/2023(UTC)
Offline alisin
#3 Posted : 19 January 2023 03:43:15(UTC)
alisin
Hey Alvaro, that is really cool, I didn't know you could do that in SMath. Thank youClap
Offline alisin
#4 Posted : 19 January 2023 21:33:01(UTC)
alisin
Hey Alvaro,
I was testing out your methods with the inclusion of loops and it seems that I can't create a variable beforehand and assign it, it has to be empty. Do you know a way around this?
This is ultimately what I am trying to do with these functions, where I can get a mutable array of "Zones", each with their own properties (ie. area, x/y location etc.)
For reference I read through this thread as well: https://en.smath.com/for...iable-Name--str2var.aspx
and tried some of the solutions posted on there but to no avail.
Offline alisin
#5 Posted : 19 January 2023 22:28:07(UTC)
alisin
I figured it out, just don't know a way around it. Since I'm calling str2num(output_i), it's giving me the value of that expression and not the variable itself.
Offline Razonar
#6 Posted : 19 January 2023 23:22:47(UTC)
Razonar
Uruguay
Yep. You need to call str2num at the worksheet level. Something like this
obj_set_get.sm (19kb) downloaded 5 time(s).
Also, I'm go to modify the code for accept set or collections.
Offline overlord
#7 Posted : 20 January 2023 03:32:59(UTC)
Turkey
Was thanked: 481 time(s) in 319 post(s)
Jean's reply is not corresponding with question.
This algorithm is not creating an object.
It is only finding index of a key in data.
thanks 2 users thanked overlord for this useful post.
on 20/01/2023(UTC),  on 20/01/2023(UTC)
Offline Razonar
#8 Posted : 20 January 2023 04:08:17(UTC)
Razonar
Uruguay
Thanks.
Updated.
obj_set_get V2.sm (47kb) downloaded 20 time(s).
obj_set_get V2.pdf (155kb) downloaded 12 time(s).
Offline alisin
#9 Posted : 20 January 2023 19:57:13(UTC)
alisin
Thanks.
Updated.
This is incredible work, it would be really cool to see this kind of feature built-in to SMath in the future.
#10 Posted : 20 January 2023 23:30:40(UTC)
Was thanked: 1318 time(s) in 869 post(s)
mod: Deleted since it was off-topic.
@Jean: please stay on topic.
Offline alisin
#11 Posted : 21 January 2023 03:50:59(UTC)
alisin
Thanks.
Updated.
I"ve been absolutely loving using this! Is there a way to disable the historical value saving? I'm trying to override some values rather than keep a record of them, I was thinking of going through a loop that check to see if the second column is zero and making a new submatrix without that row and calling it recursively until there are no 0 values left, however that presents a future problem when the value I want to set is 0. Is there a way around this?
Offline Razonar
#12 Posted : 21 January 2023 05:32:36(UTC)
Razonar
Uruguay
... Is there a way to disable the historical value saving? ...
Hi. A version without values history.
obj_set_get V3.sm (54kb) downloaded 15 time(s).
Offline uni
#13 Posted : 21 January 2023 09:23:13(UTC)
uni
Was thanked: 1256 time(s) in 731 post(s)
Maybe this plugin will be useful: Wiz Functions
It contains a set of functions for manipulating key and value pairs.
Russia ☭ forever
Viacheslav N. Mezentsev
