Offline netsonicyxf
#1 Posted : 09 January 2023 05:46:05(UTC)
netsonicyxf
Is it possible to add more pleasing higher order derivative, like these?
#2 Posted : 09 January 2023 17:19:36(UTC)
Originally Posted by: netsonicyxf Go to Quoted Post
Is it possible to add more pleasing higher order derivative, like these ?
More Derivatives is limited by the symbolic of f(x)
More pleasant ... from invention.
#3 Posted : 09 January 2023 18:37:18(UTC)
...make it algo style for in-situ command line.
#4 Posted : 09 January 2023 19:19:06(UTC)
Maths Derivative GENERALISED algo.sm (10kb) downloaded 8 time(s).
Offline mkraska
#5 Posted : 09 January 2023 21:02:06(UTC)
mkraska
SMath has a built-in prime operator ()'. It can be created but will not be evaluated in the base configuration of SMath Studio
The Maxima plugin links this operator to the function Diff(1), which computes the total derivative of an expression with respect to all variables in that expression. You can mark symbolic constants in the expression by making them custom units (writing them with a leading prime like 'y).
The function Diff(1) is always avaliable if the Maxima plugin is installed, yet the operator form must explicitly be "hijacked" by the command MaximaTakeover().
It is then available as diff(1) in the dynamic assistant.
You can create second derivatives using nested ()' operators but that doesn't look good. Perhaps appropriate operators could be defined in the custom glyphs plugin.
diff1.sm (9kb) downloaded 6 time(s).
Edited by user 09 January 2023 21:09:17(UTC)  | Reason: Not specified
Offline Razonar
#6 Posted : 10 January 2023 00:56:03(UTC)
Razonar
Uruguay
Hi. Some notes.
SMath has a built-in prime operator ()'. It can be created but will not be evaluated in the base configuration of SMath Studio ...
You can assign it to a partial derivative like operator inside SMath. (First example in the image)
... The Maxima plugin links this operator to the function Diff(1), which computes the total derivative of an expression with respect to all variables in that expression. You can mark symbolic constants in the expression by making them custom units (writing them with a leading prime like 'y).
Maxima is a great plugin. You can have it and prime as partial derivative, this is, it is not necessary to use units to mark variables other than the variable of the derivative. (Last example in the image)
diff1.sm (21kb) downloaded 6 time(s).
Offline netsonicyxf
#7 Posted : 10 January 2023 04:27:38(UTC)
netsonicyxf
Hi Jean,
Thank you for the detailed examples. But how do you input the "n" on the top?
Offline netsonicyxf
#8 Posted : 10 January 2023 04:30:08(UTC)
netsonicyxf
@mkraska, @Razonar
Thank you for the exaples.
So I can use nested 1st order derivative to get higher order derivative.
#9 Posted : 10 January 2023 05:03:19(UTC)
Hi Jean,
Type n at bottom, top follows automatically.
on 10/01/2023(UTC)
#10 Posted : 10 January 2023 05:07:00(UTC)
Maths Derivative GENERALISED algo.sm (10kb) downloaded 12 time(s).
