Offline overlord
#1 Posted : 03 December 2022 21:26:00(UTC)
Turkey
Was thanked: 526 time(s) in 352 post(s)
Augmented version & re-tutored.
This statement is wrong in your document.
Iteration is not an attribute of recursion, neither directly or implicitly.
It doesn't guess next result recursively, recursion means calling function by itself.
Recursion is a function which calls itself.
Iteration is simply repetition of a code block.
Here is sample for iteration and recursion.
Usually recursion takes more time to compute.
fibonacci.sm (8kb) downloaded 41 time(s).
thanks 2 users thanked overlord for this useful post.
on 03/12/2022(UTC),  on 06/12/2022(UTC)
Offline overlord
#2 Posted : 04 December 2022 10:43:39(UTC)
Turkey
Fibonacci sequence starts with 0. Your sample is wrong.
0,1,1,2,3,5,8,13,21,34,55
Offline overlord
#3 Posted : 04 December 2022 17:05:03(UTC)
Turkey
I won't update my code, because it is the correct one.
Fibonacci sequence start with 0 and 1.
If web calculators doesn't include 0, it is their problem.
https://en.wikipedia.org/wiki/Fibonacci_number
Offline overlord
#4 Posted : 04 December 2022 20:13:31(UTC)
Turkey
Fibonacci sequence starts with 0-1, end of debate.
I will try to point out and correct a miscalculation if I could.
I don't care if it is online calculator, mathcad, matlab, smath, etc.
I will always detract when a calculation is wrong and justified.
And I will mock and ridicule it if that mistake defended without reason.
It is time for you to learn when to stop.
Don't post your ridicule ideas and calculations.
And don't humiliate yourself anymore.
Offline overlord
#5 Posted : 05 December 2022 00:19:32(UTC)
Turkey
Good idea you detract yourself from your wrong code.
Fibalgo(26)=121393
You are totally incapable calculating even a very simple thing, AGAIN.
My code is correct, yours is wrong. And this didn't surprised me one bit.
Offline overlord
#6 Posted : 05 December 2022 03:49:55(UTC)
Turkey
You have mistaken index numbers, since smath vector index start with 1.
Near all other calculators starts index with 0.
fib(0) is 0 for them, fib(1) is 0 for smath.
So yeah, fib(26) is 75025 in SMath.
Online Razonar
#7 Posted : 05 December 2022 20:04:27(UTC)
Razonar
Uruguay
Was thanked: 859 time(s) in 545 post(s)
Maths Fibonacci VERDICT Copy.sm (24kb) downloaded 28 time(s).
What is your concept of "hyperfast" and "command line"? Did you do any kind of testing before making such strong statements? Please do some basic research before posting solutions that are not.
f.sm (5kb) downloaded 27 time(s).
on 06/12/2022(UTC),  on 06/12/2022(UTC)
Online Razonar
#8 Posted : 06 December 2022 00:17:23(UTC)
Razonar
Uruguay
1. Command line is pretty universal. Remember Mathsot times.
Sure it is. This is what SMath developers understand about "command line", which matches the universally accepted concept for that expression ( from https://en.smath.com/view/SMathStudio/faq )
So could you show where the "command line" is in your example?
2. Computing 1476 Fibonacci in < 1 s
is hyperfast to me versus Julia set 2 hrs !!!
So, you test your fib against your Julia set ... Do you try to test your fib versus another function that returns Fibonacci numbers?
f.sm (9kb) downloaded 24 time(s).
#9 Posted : 06 December 2022 16:15:51(UTC)
Was thanked: 1367 time(s) in 894 post(s)
mod: I've merged the threads, if you have different methods you can list or link them in the first post with the edit button. Unless there is a crystal clear difference in methods and a meaningful title, having multiple threads about the same thing makes really hard to navigate and search topics in the forum.
I agree you should give proper names to things, recursion and iterations are two very different things and they have an estabilished meaning (like "command line", I'm sure this was already discussed in some other thread previously)
To quote myself, this is another simple way to create a Fibonacci sequence in SMath Studio.
Originally Posted by: Davide Carpi Go to Quoted Post
Yes you can, but you have to work in base 1 indices (first vector element index is 1, 18th elemnt index is 18).
https://it.smath.com/cloud/worksheet/ZHppgvSG
Edited by user 06 December 2022 16:19:56(UTC)  | Reason: Not specified
#10 Posted : 14 December 2022 22:28:37(UTC)
That's all what you need, more is offered.
Maths Fibonacci VERDICT Short.sm (10kb) downloaded 26 time(s).
Maths Fibonacci VERDICT Copy.sm (428kb) downloaded 25 time(s).
Offline alyles
#11 Posted : 14 December 2022 23:59:44(UTC)
alyles
Was thanked: 92 time(s) in 58 post(s)
The verdict is in.
#12 Posted : 16 December 2022 20:39:58(UTC)
Similar Topics
Fibonacci VERDICT (Samples)
by Jean Giraud 14/12/2022 22:28:37(UTC)
Fibonacci Plus (Samples)
by Jean Giraud 03/12/2022 18:33:49(UTC)
fibonacci sequence (Questions)
by plchild 23/01/2020 22:54:00(UTC)
