I'm not sure, but I think I might have found a bug: I remember this used to work before. Am I doing something wrong? Edited by user 01 December 2022 11:01:35(UTC)
| Reason: Not specified
Originally Posted by: S0lo I'm not sure, but I think I might have found a bug: I remember this used to work before. Am I doing something wrong? You need to use line operator in function definition. Edit: A note about recursion. I do believe that Andrey limited the recursion depth that can take place. I think its somewhere around 50. Edited by user 30 November 2022 16:20:30(UTC)
1 user thanked alyles for this useful post.
Example of recursion limit. |
Originally Posted by: alyles Originally Posted by: S0lo I'm not sure, but I think I might have found a bug: I remember this used to work before. Am I doing something wrong? You need to use line operator in function definition. Edit: A note about recursion. I do believe that Andrey limited the recursion depth that can take place. I think its somewhere around 50. Thanks!! How did I forget that. heh.
The Mathematica 4.0 Fibonacci recursion has Smath companion algo style.
Originally Posted by: Jean Giraud The Mathematica 4.0 Fibonacci recursion has Smath companion algo style. That is not an example of recursion, that is an iterative method. Try googling something like "iterative vs recursive Fibonacci". Alvaro.
on 01/12/2022(UTC), on 01/12/2022(UTC)
on 02/12/2022(UTC), on 02/12/2022(UTC)
