SMath Studio Forum
Questions
Import results from another smath studio file
Hello, Is it possible to import a results from another smath studio file and then use it as a imput for the second file? Thanks
Joined: 23/07/2013(UTC) Posts: 1,126 Was thanked: 507 time(s) in 338 post(s)
Use include() function. Learn more from Reference Book.
To be ensure new users not getting confused by Jean's immorally promoted and irrelevant samples; Question was calculating and getting result from another worksheet. Not writing results into file getting them in same sheet. Here is an example how include() can be used. Regards include_main.sm (4kb) downloaded 15 time(s). include_sub.sm (3kb) downloaded 13 time(s).
2 users thanked overlord for this useful post.
on 28/11/2022(UTC), on 28/11/2022(UTC)
Hello guys! Thank for the support. Bye
Originally Posted by: coeur_de_lion Is it possible to import a results from another Smath Studio file and then use it as a input for the second file? . You can try from the attached. As given, re-code the the referenced include(,) Should work as they will be from the same download directory. Genfit Minimize Include Test.sm (59kb) downloaded 8 time(s). Genfit Minimize Include.sm (32kb) downloaded 7 time(s).Include(,) is more for advanced maths
Originally Posted by: coeur_de_lion Is it possible to import a results from another Smath Studio file and then use it as a input for the second file? Answer is YES ... from various results.... imported from SmathFile into main Directory.
SMath studio has the built-in functions rfile() and wfile() which are used to store and retrieve expressions to/from the file system. These native functions don't provide control as to where the files are stored (if I recall correctly, it is the settings directory (install directory if using a portable version). Yet the Mathcad toolbox plugin provides extended functions with path control, e.g. you can enforce storage at the document directory. wfile.sm (4kb) downloaded 8 time(s). |
Jean, stop messing people's topics. Post this not-related replies to samples.
SMath Studio Forum
Questions
