Hello everyone, I have such a task here, you need to find y (x) for each value of x in the range from 1.2 to 2.4 with a step of 0.2. X I managed to display and see the result. However, when writing the formula y(x) and trying to display y(x), it gives an error. help me please Plus I can't figure out how to write sin^2(x) in order to have a formula... Edited by user 27 September 2022 00:16:32(UTC)
| Reason: Not specified
Originally Posted by: Parlepanpindipon Hello everyone, I have such a task here, you need to find y (x) for each value of x in the range from 1.2 to 2.4 with a step of 0.2. X I managed to display and see the result. However, when writing the formula y(x) and trying to display y(x), it gives an error. help me please Plus I can't figure out how to write sin^2(x) in order to have a formula...
And the result should be displayed as x = {}
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Seems to be a very old version of SMath Studio (display of ranges, round matrix brackets). May well be that the vectorize function isn't available yet in that version. You might consider upgrading or you have to use an explicit loop with for or while. |
Joined: 23/07/2013(UTC) Posts: 1,124 Was thanked: 506 time(s) in 337 post(s)
Let's visualize what Martin has perfectly described.
Originally Posted by: churichuro Oh, I'm sorry, could you tell me how to make a vector over y(x)?
Originally Posted by: mkraska Seems to be a very old version of SMath Studio (display of ranges, round matrix brackets). May well be that the vectorize function isn't available yet in that version. You might consider upgrading or you have to use an explicit loop with for or while. Ok, I tried to do it through the "for" loop, but it didn't work out very well for me, can you tell me how to do it?
you can either click Vectorize button at right tool window, or directly write vectorize as it is a function.
You can see the button in picture I have uploaded at post #6.
Originally Posted by: overlord you can either click Vectorize button at right tool window, or directly write vectorize as it is a function.
You can see the button in picture I have uploaded at post #6. by clicking on vectorize I have the following
That's the dinamic assistance when you write directly vectorize Here is the vectorize button as shown by overlord in post #6As stated by mkraska, it is possible that you are using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x) Edited by user 27 September 2022 12:00:33(UTC)
Originally Posted by: Davide Carpi That's the dinamic assistance when you write directly vectorize Here is the vectorize button as shown by overlord in post #6As stated by mkraska, it is possible that you might using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x) ok, I understand, but when I write vectorization, there is no such component, most likely there is simply no plugin or am I mistaken?
Originally Posted by: Parlepanpindipon Originally Posted by: Davide Carpi That's the dinamic assistance when you write directly vectorize Here is the vectorize button as shown by overlord in post #6As stated by mkraska, it is possible that you might using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x) ok, I understand, but when I write vectorization, there is no such component, most likely there is simply no plugin or am I mistaken?
Therefore you are in this case: Originally Posted by: Davide Carpi As stated by mkraska, it is possible that you might using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x) You have to update to a new version if you want to take advantage of vectorize, otherwise you have to use a loop from the programming palette (for or while); here you have a couple of ways loops.sm (8kb) downloaded 6 time(s).BTW vectorize() is available in stable releases since SS 0.98.5935 (April 2016); square brackets in ranges are more recent, since SS 0.98.6593 (January 2018) Edited by user 27 September 2022 13:08:31(UTC)
Originally Posted by: Parlepanpindipon Plus I can't figure out how to write sin^2(x) in order to have a formula... sin²(x) is silent code for purpose, often replied by maple You have to code it as exemplified. Cheers ... Jean. Maths sin2(x) plot.sm (7kb) downloaded 4 time(s).
... Previous Smath document has been removed from Smath Community.
Originally Posted by: Parlepanpindipon Plus I can't figure out how to write sin^2(x) in order to have a formula... I missed this part, sorry. Simply type this sequence (the highlighted content): sin( > x > keyboard right arrow > ^ > 2tricks like those shown by Jean Jiraud above are useful if you want to disply the content in a different way or in other cases beyond a beginner level needs (in other words, there is no need to overcomplicate the things here). Here you have your example with sin^2(x) and probably the more compact way to make it working in your Smath Studio version. Parlepanpindipon_sin2(x).sm (6kb) downloaded 6 time(s).Edited by user 27 September 2022 15:10:39(UTC)
Originally Posted by: Davide Carpi Originally Posted by: Parlepanpindipon Plus I can't figure out how to write sin^2(x) in order to have a formula... I missed this part, sorry. Simply type this sequence (the highlighted content): sin( > x > keyboard right arrow > ^ > 2tricks like those shown by Jean Jiraud above are useful if you want to disply the content in a different way or in other cases beyond a beginner level needs (in other words, there is no need to overcomplicate the things here). Here you have your example with sin^2(x) and probably the more compact way to make it working in your Smath Studio version. Parlepanpindipon_sin2(x).sm (6kb) downloaded 6 time(s). Thx, very much
Originally Posted by: Parlepanpindipon tricks like those shown by Jean Jiraud above are useful ... no tricks in there, just productive project at will, that you didn't download, i.e: not helping yourself !
