2 Pages12>
Offline RFreund
#1 Posted : 21 September 2022 21:40:35(UTC)
RFreund
Was thanked: 19 time(s) in 17 post(s)
How can I remove a row or column from a matrix while keeping all assigned units to the elements in the matrix.
For example let's say that I have a matrix with the first column containing all text, the next column contains numbers with units of inches, and the next column has units of pounds. I want to create a new matrix but I want the entire 3rd row removed. I also want to keep the appearance of the units (i.e. text, inches, lbs).
Is this possible?
Thanks!
Online overlord
#2 Posted : 22 September 2022 01:21:22(UTC)
Turkey
Well you can't show it with conventional ways if it contains string column.
I am not sure if it is possible when a string column is absent if it has mixed units.
However, you can use a table region to show your new matrix.
Not an ideal solution, but it is what we can have.
#3 Posted : 22 September 2022 13:02:40(UTC)
Something like this?
rmRows_rmCols.sm (36kb) downloaded 13 time(s).
Offline PompelmoTell
#4 Posted : 22 September 2022 17:16:00(UTC)
PompelmoTell
I believe that rfreund wanted to keep the units of measurement set. I take Davide's solution and I add a trick (I think he had been offered by Overlord or Razonar or perhaps from both).
However, I still have to solve for the strings. Furthermore, if we cancel the columns instead of the lines we should build the units of measurement of the matrix resulting with the same method.
rmRows_rmCols_units.sm (16kb) downloaded 12 time(s).
on 15/11/2022(UTC)
Online overlord
#5 Posted : 23 September 2022 01:14:03(UTC)
Turkey
I first see usage of diag() for units by Razonar, then just wrote it as in your example.
Another way is using pseudo units, but this is also not interchangeable.
Again, these are not conventional ways. Just holding your left ear with your right hand.
And there is no solution for string column I guess.
matrix mixed units.sm (10kb) downloaded 7 time(s).
Offline mkraska
#6 Posted : 23 September 2022 10:26:49(UTC)
mkraska
One might use vector-valued indices.
rmRows_rmCols_Kr.sm (8kb) downloaded 10 time(s).
Online overlord
#7 Posted : 23 September 2022 14:55:30(UTC)
Turkey
All you missing some points of Rfreund's question, except Sergio.
He asked for a string column, an inch column and a pound column.
And showing result matrix as written. This is the tricky part.
Not removing rows of an ordinary matrix with SI units.
He specifically asked removing a row of mixed non-SI units matrix.
And displaying it with non-SI units.
Online overlord
#8 Posted : 23 September 2022 16:32:58(UTC)
Turkey
That will reduce the fractal replies.
It is clear what Rfreund has asked, no need to upload an smath file.
Take this matrix, remove its third row, make it look like as intended.
With its string and non-SI columns displayed as they are.
Offline mkraska
#9 Posted : 24 September 2022 11:56:56(UTC)
mkraska
So the topic is "display of matrices in non-default units". No idea if the presence of strings is relevant for the problem.
This question is another vote for a function defaultUnit(u).
This function would be inserted wherever appropriate in a document.
An option to set the default units by document or system-wide in the units dialog would be helpful. Otherwise, we will see many documents starting with blocks of unit settings. Yet, still the above-mentioned function would be required, because at different places in a document you might need different settings.
Of course, if you want to mix different units of the same quantity, then setting the default unit would not help either.
Online overlord
#10 Posted : 24 September 2022 13:56:57(UTC)
Turkey
This is how it is relevant, somehow you can view your matrix with method I have showed.
But if matrix contains a string column, the sample below won't work too.
That's what Rfreund asked I guess, string and mixed units columns viewing.
on 14/11/2022(UTC)
#11 Posted : 24 September 2022 15:34:28(UTC)
on 14/11/2022(UTC)
Offline mkraska
#12 Posted : 25 September 2022 00:20:23(UTC)
mkraska
Thanks for clarification. Perhaps overloading the multiply operator to strings could help then, but that is probably too far-fetched. 1*"a"="a", 2*"a"="aa".
For now I just stick with displaying individual columns with custom units instead of whole matrices or in rare cases I use tables.
on 14/11/2022(UTC)
Offline loha
#13 Posted : 25 September 2022 08:47:33(UTC)
loha
Was thanked: 9 time(s) in 9 post(s)
Fascinating catalog of examples!
Thanks to all!
That all these neat and concise writings are possible really show how brilliant Smath is as a software!
Offline RFreund
#14 Posted : 14 November 2022 20:49:45(UTC)
RFreund
Thanks for all your efforts on this. Very impressive!
Also sorry for being ambiguous. My question really was twofold - First, can I simply remove a row or column and keep the assigned units. Second, can we do this with Text. Seems as though the answer is yes and no. Yes, you can remove the row or column, but no you cannot get it to display in non-SI units.
The table idea isn't bad, but I really like having more control over what units are displayed or are considered default.
Thanks again.
Edited by user 15 November 2022 00:32:19(UTC)  | Reason: I finally read the responses.
#15 Posted : 16 November 2022 14:51:17(UTC)
Smath is delivered with silent units or active SI ...
... silent units as required
Page4 Delete Col-Row.sm (16kb) downloaded 6 time(s).
Offline RFreund
#16 Posted : 17 November 2022 05:04:59(UTC)
RFreund
Martin - I didn't realize that you could use "vector-valued indices" to reorganize matrices. That might be useful to me in the future. Although I suppose using the submatrix function is pretty similar.
Jean - it took me a minute to understand "silent-units" as I thought the apostrophe in front of the unit solved the unit "display" issue. I guess it does if you only want it to "look correct". Thanks for your efforts.
Offline mkraska
#17 Posted : 17 November 2022 14:20:36(UTC)
mkraska
The index vector approach is more flexible, as it allows to pick arbitrary subsets of rows and columns instead of continuous ranges.
iv.sm (5kb) downloaded 8 time(s).
#18 Posted : 17 November 2022 17:38:10(UTC)
Silent mode disables the SI unit sub-processor.
Don't miss visiting this great matrix shuffling utility.
Utilities Matrix Shuffle.sm (13kb) downloaded 5 time(s).
#19 Posted : 17 November 2022 17:50:17(UTC)
... this clean version.
Utilities Matrix Shuffle.sm (15kb) downloaded 10 time(s).
Offline RFreund
#20 Posted : 18 November 2022 06:59:14(UTC)
RFreund
@Martin - Good point. I still don't know how I will use this feature, but I already see it being a little more difficult to use in some sort of function. Just seems like it lends itself to manual creation of the vector used in the indices, but I suppose you just need to be creative enough.
2 Pages12>
