SMath Studio Forum
Questions
It's possible to block the negative input in field's?
Joined: 28/02/2022(UTC) Posts: 18   Was thanked: 2 time(s) in 2 post(s)
Hey Guys,
It's possible to block the negative input in field's using smath viewer?
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,531   Location: Italy Was thanked: 1269 time(s) in 834 post(s)
Nope, the best way to accomplish it easily is to filter the output applying abs() to the value before using it.
a:1
a:abs(a)
f(a): ... |
Thanks Davide! Actually i do this, i will use an formatted label to show some message warning the user
You are welcome. As alternative one can develop a region that translates into a TextBox control with mask/validation filters. It might be tricky depending on the filter but it is feasible. |
Wow! It will be a great plugin! It can be extend the use of smath viewer in so many ways
Originally Posted by: Jean Giraud  Originally Posted by: Hildebrando Pereira  It's possible to block the negative input in field's using smath viewer ? Pretty simple to zap negative values: 1. transform negatives to '0' 2. strip vector from '0' No need using Smath Viewer. Cheers ... Jean. Random [rnd(n)] Filter.sm (11kb) downloaded 7 time(s).Composite clean negatives.  Thanks Jean, but it's not the case. I have an long application developed in Smath Studio using Smath Viewer, and some of my algorithms need's a positive input for bending moment's. For now showing a warning message, and using an absolute value work, it's not the more elegant solution, but work.
Originally Posted by: Jean Giraud  Originally Posted by: Hildebrando Pereira  I have an long application developed in Smath Studio ... , and some of my algorithms need a positive input for bending moment's. The very original document at the algorithms level might help. Not my discipline, but curious. Refreshed version of the previous Filter Negatives.Jean. Random [rnd(n)] Filter.sm (11kb) downloaded 6 time(s). Sure! The document is here: DIMIS_219.sm (839kb) downloaded 12 time(s).The section is called "Flexão Composta" the value of Msd, for this algorithm need's to be positive.
Joined: 23/07/2013(UTC) Posts: 898  Was thanked: 358 time(s) in 239 post(s)
Originally Posted by: Hildebrando Pereira  Thanks Jean, but it's not the case. Get use to what he do, but never bow down or surrender. He will try to hijack your topics with totally unrelated replies. Just report his irrelevant posts, mods will take care it eventually. Regards
SMath Studio Forum
Questions
