2 Pages12>
Offline Neeky
#1 Posted : 24 August 2022 17:25:23(UTC)
Neeky
Dear forum users! I turn to you for advice on the SMath program. I am attaching a file in .sm format with suggestions for improving the accuracy of calculations in the SMath program and questions for the presented calculation.
Found an error in the last question. I am attaching the updated file.
Improving Calculation Accuracy.sm (79kb) downloaded 12 time(s).
Edited by user 26 August 2022 10:29:46(UTC)  | Reason: Error in the last question
Offline Razonar
#2 Posted : 25 August 2022 01:15:42(UTC)
Razonar
Uruguay
Hi Neeky. Some notes about your questions.
Improving Calculation Accuracy.sm (34kb) downloaded 22 time(s).
Improving Calculation Accuracy.pdf (255kb) downloaded 29 time(s).
on 25/08/2022(UTC),  on 25/08/2022(UTC)
#3 Posted : 25 August 2022 13:59:00(UTC)
... this version for your convenience.
Previous deleted.
Improving Calculation Accuracy RootSecant.sm (29kb) downloaded 20 time(s).
on 25/08/2022(UTC)
Offline Neeky
#4 Posted : 26 August 2022 16:36:02(UTC)
Neeky
Thank you very much for the tip to use the bisection method!
Please tell me how it is possible to implement in the SMath program an algorithm for calculating the roots of an equation that (an equation) contains Bessel functions. Equation with Bessel functions.sm (4kb) downloaded 10 time(s).
#5 Posted : 26 August 2022 20:24:54(UTC)
Immediately, answer is no from Smath built-in Bessel... Why ?
Smath built-in Bessel has no derivative for roots solver.
Visit ► Samples ► Solve Grand TREASURY ► sheet 0
You can have Bessel from Computer Approximation ... attached.
Bessel J0,Y0.sm (23kb) downloaded 13 time(s).
on 29/08/2022(UTC)
Offline Razonar
#6 Posted : 27 August 2022 04:25:12(UTC)
Razonar
Uruguay
Hi. Use bisection method.
Equation with Bessel functions.sm (25kb) downloaded 24 time(s).
Equation with Bessel functions.pdf (78kb) downloaded 14 time(s).
Edited by user 27 August 2022 04:28:52(UTC)  | Reason: Not specified
on 29/08/2022(UTC)
#7 Posted : 27 August 2022 15:20:06(UTC)
This document solve Smath built-in mwbesselj(0,x)
1. rootDichotomy for the roots.
2. rootSecant for solving intersection with linear f(x) ... typical.
Jean.
Bessel SOLVE.sm (23kb) downloaded 15 time(s).
on 29/08/2022(UTC)
Offline Neeky
#8 Posted : 29 August 2022 15:47:41(UTC)
Neeky
Thanks for the help.
Now I can determine the roots of such equations.
My calculations that contain these equations are calculated correctly.
The only thing I don't understand is the algorithm presented in Razonar's post..
Could you please tell me how to deal with this algorithm?
Offline Razonar
#9 Posted : 29 August 2022 21:23:42(UTC)
Razonar
Uruguay
Hi. Some comments added.
Equation with Bessel functions Explain.sm (43kb) downloaded 10 time(s).
Equation with Bessel functions Explain.pdf (259kb) downloaded 10 time(s).
Edited by user 29 August 2022 21:30:15(UTC)  | Reason: Not specified
on 30/08/2022(UTC),  on 30/08/2022(UTC)
#10 Posted : 29 August 2022 22:47:10(UTC)
If you provide a sample, that will help mutually.
As offered, you can solve for roots & intersections.
Offline overlord
#11 Posted : 30 August 2022 00:07:27(UTC)
Turkey
Mentioned procedure for finding when solve(), diff(), etc would work is useful.
Thanks
Offline Neeky
#12 Posted : 30 August 2022 11:14:28(UTC)
Neeky
Hello!
Thank you very much for your clarification and for taking the time to answer my question.
Due to the fact that I am not a mathematician or a programmer, it is still very difficult for me to understand these algorithms.
Nikolai.
#13 Posted : 30 August 2022 17:43:23(UTC)
Nikolai.
You have to be the Smth Mathematician in some of these built-in functions.
BesselJ(x,0)... is strctly 0 from x=0 ... ∞
Thus, you can multiply by anything.
As a desirable effect, it constrains
x*BesselJ(x,1)to start @ 0
for profitable inspection suite.
Psi(x)+BesselJ(x,0)renders superbly Psi(x).
What complains here is for smarter than me
Neeky.sm (22kb) downloaded 8 time(s).
on 01/09/2022(UTC)
#14 Posted : 01 September 2022 01:01:45(UTC)
Hello Nikolai,
Your Bessel PDF is interesting.
It has a close relationship with Weibull.
As demonstrated, not optimized.
Added solve roots/datum, accurate algo style.
Stat Treasury_11 PDF Weibull_Bessel.sm (17kb) downloaded 6 time(s).
on 01/09/2022(UTC)
Offline Neeky
#15 Posted : 01 September 2022 17:23:46(UTC)
Neeky
Hello Nikolai,
Hello Jean Giraud,
Thank you for your attention to my questions and for tips on how to improve the accuracy of calculations.
The equation whose roots I need to find is correctly written in SMath:
F(x) = x * Bessel(1;x) - 1,01 * Bessel(0;x).
Tell me, please, is it possible to apply the algorithm you proposed to determine the roots of this equation?
Best regards,
Nikolai
#16 Posted : 01 September 2022 19:55:17(UTC)
... is it possible to apply the algorithm you proposed to determine the roots of this equation?
Immediate answer is NO from brute force.
I try to manage my Waterloo ... !
on 02/09/2022(UTC)
#17 Posted : 01 September 2022 23:36:35(UTC)
Now, answer is YES from individual Dichotomy.
Accuracy is in the range of ~ 15 D.
Enjoy ... Jean.
Nikolai roots.sm (45kb) downloaded 11 time(s).
on 02/09/2022(UTC)
#18 Posted : 02 September 2022 14:37:58(UTC)
... here is your project Nikolai !
As far as I understand your roots demand.
f(x) is not scalar wrt 'x' for the solver/scanner solve(■,■,■,■)
but compatible with roots-Dichotomy command line.
Please, don't hesitate for more ... Jean.
Nikolai roots.sm (59kb) downloaded 12 time(s).
on 02/09/2022(UTC)
Offline Neeky
#19 Posted : 02 September 2022 15:35:52(UTC)
Neeky
Jean and Alvaro thank you very much for your efforts.
It was extremely important to get feedback on this issue.
Now my knowledge of mathematics and programming has been improved.
Best regards,
Nikolai
#20 Posted : 02 September 2022 21:50:21(UTC)
This augmented version includes min/max Golden ratio.
In case you would want to fit upper/lower envelope,
you will need those support points and more.
Nikolai roots.sm (79kb) downloaded 8 time(s).
Guest (2)
2 Pages12>
