Offline JuanMa_arg
#1 Posted : 25 August 2022 16:12:59(UTC)
JuanMa_arg
Rank: Member
Argentina
Dears,
I would like to ask you how the if then else control statement is used in SMath Studio version 1.0 8253.
When I insert the if statement, the else does not appear. How is it incorporated? I saw in videos that when placing the if statement both appear, the complete if x else x statement. In the version I use, only the if appears.
Another query, ¿in which plugin is the CAUSES() statement, which is an if then else version to generate functions by sections (piecewise function)?.
Thank you all
Cheers
Juan
Edited by user 25 August 2022 16:15:38(UTC)  | Reason: add image
Offline PompelmoTell
#2 Posted : 25 August 2022 16:39:45(UTC)
PompelmoTell
See here
on 26/08/2022(UTC)
#3 Posted : 25 August 2022 16:52:08(UTC)
if/otherwise from the f(x) menu ... cases
if/else from the palette.
Offline JuanMa_arg
#4 Posted : 25 August 2022 17:02:55(UTC)
JuanMa_arg
Rank: Member
Argentina
Originally Posted by: PompelmoTell Go to Quoted Post
See here
Thanks Pompelmo!
Offline JuanMa_arg
#5 Posted : 25 August 2022 17:05:30(UTC)
JuanMa_arg
Rank: Member
Argentina
Thanks Jean, will i need a plugin?
Offline overlord
#6 Posted : 25 August 2022 19:13:17(UTC)
Turkey
He doesn't use latest version. In fact, he uses 6 year old version of smath (v0.99.6179).
The version he uses has not capability of "if, if/else". That has only "if/else". New function is intruduced with v1.0.8206.
He has no idea what is going on, just listen what Sergio said. And if you read he insist to use smath "unitless" or use "silent units", ignore anything he says after that. Just wait for a sane experienced user to reply.
cases() is a plugin function. It works similar to if/else. You need to install Custom Functions plugin.
on 25/08/2022(UTC)
Offline JuanMa_arg
#7 Posted : 25 August 2022 22:32:19(UTC)
JuanMa_arg
Rank: Member
Argentina
Thanks Overlord
