Joined: 02/06/2017(UTC) Posts: 18 Location: Stoke on Trent
I'm getting the following error when saving a sheet i'm using Version 1.0 (build 8151) I've tried disabling various extensions but its still happening Any help will be much appreciated |
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
Originally Posted by: Peter J Francis Any help will be much appreciated Try disable AV's [Anti Virus] before saving.
Hi Jean Thanks for the reply , I tried that .... still get the error
I've also tried it on 2 different PCs with no luck |
Peter J Francis
Originally Posted by: Peter J Francis Hi Jean Thanks for the reply , I tried that .... still get the error From recollection, I think Davide could recuperate. Wait and expect SS Community will help. Jean
- Update SMath to latest stable (1.0.8253), - Update all installed plugins to latest versions, - Try to run SMath as administrator.
The error message seems related to something in the ImageEditRegion plugin Code:<ProjectGuid>{63DDAEF8-9A56-4FF6-938E-D590B638BF99}</ProjectGuid>
Thanks Davide, I just disabled ImageRegion plugin and the error disappeared when i saved the sheet
Overlord - thanks for your answer I can't upgrade to the latest stable yet as the client is using the same version as I am thank you all for your help
Peter |
Peter J Francis
