SMath Studio Forum
Questions
there is any mistake, Please solve this attached file
2 psc beam bridge(US unit)-Dead Load.sm (193kb) downloaded 9 time(s).I can not have a right calculation results though I tried to resolve this several times. When I am using the matrix format, I get the wrong results. In case that I am using the simple format x=20ft, I get the right result. Please help me out. Edited by user 19 August 2022 02:11:14(UTC)
| Reason: Not specified
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
Since x is a matrix and you are using it with other variables, you have to use vectorize. You can either write it as a function or click to its button on toolbar > matrices. Regards
Originally Posted by: John Bhang I can not have a right calculation results though I tried to resolve this several times. You can make each demand algo style 1rst demand exemplified. The algo style will support in-situ infinite command line. ... in-situ infinite command line wrt [u,v,x]A damned elegant Pro. style project !
SMath Studio Forum
Questions
