Offline James Mazon
#1 Posted : 06 August 2022 18:59:16(UTC)
James Mazon
Brazil
I´m having problems with the if function on the programming pallete. When I choose "if" from the pallete it just shows two lines, there is no else anymore like on the image in the attachment. If I recall correctly the else statement used to automatically appear when you choose the "if" function from the pallete. Could someone help me understand what´s happening?
Edited by moderator 08 August 2022 11:19:55(UTC)  | Reason: big image moved inside spoiler
Offline PompelmoTell
#2 Posted : 06 August 2022 20:03:26(UTC)
PompelmoTell
First of all, check in Tools-Option-->Interface-->Arguments separators which setting you set up. They are possible "," "." ";".
Suppose it is ";".
In the placeholder digit once ";" to get Else or ";;" to get Elseif
Offline James Mazon
#3 Posted : 07 August 2022 18:12:44(UTC)
James Mazon
Brazil
Thank you! It worked
