2 Pages<12
#21 Posted : 05 July 2022 21:35:25(UTC)
Confirmed: works fine SS 6179
#22 Posted : 06 July 2022 02:55:11(UTC)
Originally Posted by: avp Go to Quoted Post
What does this mean for me as a Smath user ?
Simoly: hope some user of your SS version will catch/isolate the bug.
Offline Razonar
#23 Posted : 06 July 2022 03:24:50(UTC)
Razonar
Uruguay
Was thanked: 925 time(s) in 588 post(s)
Thank you. But the problem is not because of eval(). She's somewhere deeper. My f3(x) and f4(x) limits are ainterp() of the table data.
Hi avp. Try using eval() for ainterp().
on 06/07/2022(UTC)
Offline avp
#24 Posted : 06 July 2022 09:38:05(UTC)
avp
Rank: Member
Thanks, this is how the integrals are calculated, but the function containing the integral inside still returns an error. Accordingly, the final result of the calculations still failed to be obtained.
Proizvol'noe sechenie_no XLSX.sm (74kb) downloaded 11 time(s).
#25 Posted : 06 July 2022 15:29:07(UTC)
The type errors your version reports is
wrt some limit(s) of the double integration.
Why specific to this version ?
Offline avp
#26 Posted : 06 July 2022 17:00:48(UTC)
avp
Rank: Member
I dont know. I wanted to know here why the calculation of integrals, which used to work well before, broke down after adding the ability to use the dimensions of units in integrals.
#27 Posted : 06 July 2022 17:54:42(UTC)
I don't know. I wanted to know here why the calculation of integrals, which used to work well before, broke down after adding the ability to use the dimensions of units in integrals.
You have a good point about units in integral.
Attached is your saved working version.
Open in your latest SS. It may rescue the integrator.
God save the Queen and avp.
Integrate Double Didactic Russia.sm (73kb) downloaded 26 time(s).
Offline Razonar
#28 Posted : 08 July 2022 09:21:11(UTC)
Razonar
Uruguay
Workarounds for the integration bug.
Proizvol'noe sechenie_no XLSX.sm (75kb) downloaded 14 time(s).
Proizvol'noe sechenie_no XLSX.pdf (261kb) downloaded 16 time(s).
Offline avp
#29 Posted : 08 July 2022 16:41:34(UTC)
avp
Rank: Member
Hi, Alvaro.
The result is not correct. The result should be Kx = 1.233, Ky = 1.044
#30 Posted : 08 July 2022 19:09:49(UTC)
... those values are same in my document.
You didn't report working/crap ?
Offline Razonar
#31 Posted : 09 July 2022 01:55:00(UTC)
Razonar
Uruguay
Hi, Alvaro. The result is not correct. The result should be Kx = 1.233, Ky = 1.044
Hi avp. I hope the problems with double integrals can be solved, because the calculation of double integrals that SMath had was quite powerful. The only way to calculate Kx, Ky would be to discretize and integrate over the cubic splines curve.
Proizvol'noe sechenie_no XLSX.sm (78kb) downloaded 13 time(s).
Proizvol'noe sechenie_no XLSX.pdf (288kb) downloaded 12 time(s).
Edited by user 09 July 2022 02:00:47(UTC)  | Reason: Not specified
#32 Posted : 11 July 2022 02:11:01(UTC)
This document is adapted/doctored in native Smath 6179.
It does not scratch Smath a bit.
As you download, after it has finished
it offers to update: click close to be back SS 6179.
Re=download and let it update latest SS.
If you have red as it complained, probably the integrator
is freaked in that version ... hard to explain.
Integrate Double Didactic Russia (3).sm (75kb) downloaded 10 time(s).
#33 Posted : 11 July 2022 03:10:02(UTC)
... code that test double integration in your latest SS.
Hoping more Collab will code as well to sanity.
2 Pages<12
