Offline PompelmoTell
#1 Posted : 25 June 2022 22:23:26(UTC)
PompelmoTell
Was thanked: 107 time(s) in 91 post(s)
In the two attached sheets I add the same problem but in the first the units of measurement are added fictitiously and the solution is correct (verified with other specific software); In the second sheet, the units of measurement are used (including the application of the new functionality of the integrals defined with units of measurement). However, in the application of the second integral I get a double value (I don't know if it is a coincidence) of the expected one.
Pressoflessione_R(um).sm (36kb) downloaded 14 time(s).
Pressoflessione_R(um_vero)_01.sm (44kb) downloaded 12 time(s).
Edited by user 26 June 2022 18:14:18(UTC)  | Reason: Not specified
Offline Razonar
#2 Posted : 26 June 2022 01:16:51(UTC)
Razonar
Uruguay
Was thanked: 682 time(s) in 426 post(s)
Ciao Sergio. It seems that you redefine b in the collapsed area, and bb have not the same value in both files.
on 26/06/2022(UTC)
#3 Posted : 26 June 2022 18:13:48(UTC)
PompelmoTell
Thanks Alvaro, a stupid error due to the re-adaptation of the sheet to the new integral functionality with measurement unit. Since I had difficulty solving the nonlinear equation directly with "solve", I used an old manual procedure that inadvertently changed the value of "b" (used as a value to trigger the iterative procedure)
