Offline tofulover
#1 Posted : 27 May 2022 18:19:56(UTC)
tofulover
Australia
I have just started to use Smath and am liking it so far.
I could not figure out how to enter values in polar form with its angle? say 100/_60deg, i.e. a magnitude of 100 and a degree of 60.
On Mathcad the polar operator is in operator -> engineering menu. I can't find similar in smath but everything else I am at home with.
I can see there is a polxy function but it is not quite the same?
Thanks
Offline uni
#2 Posted : 27 May 2022 19:57:54(UTC)
uni
You can use this method
Russia ☭ forever
Viacheslav N. Mezentsev
Offline tofulover
#3 Posted : 28 May 2022 02:25:23(UTC)
tofulover
Australia
Thanks uni for that. I tried it and it seems to work - but is it possible that i don't key in the "degree" sign and still get the same result? i.e. the polar form of 100/_60deg = 50 + j86.6.
If I dont put the degree sign it will return -95.24 -30.48i which is a different result.
Thanks
Offline uni
#4 Posted : 28 May 2022 08:24:39(UTC)
uni
Originally Posted by: tofulover Go to Quoted Post
I tried it and it seems to work - but is it possible that i don't key in the "degree" sign and still get the same result? i.e. the polar form of 100/_60deg = 50 j86.6.
Russia ☭ forever
#5 Posted : 28 May 2022 19:24:22(UTC)
Plot the circle as well.
Offline tofulover
#6 Posted : 29 May 2022 07:43:42(UTC)
tofulover
Australia
Thanks! that works well.
How would I convert from polar to rectangular but using the variable instead?
say I have this:
pol(m,a):= m.exp(a.pi/180*i)
V:=pol(1,10) = 0.9841 + 0.1736*i
I:=V/200 = 0.0049 + 0.0009*i
I want to display I in a polar form.
I can use xypolto but not so convenient.
How do I do xypol2(I) = ?
Edited by user 29 May 2022 07:54:03(UTC)  | Reason: Not specified
Offline tofulover
#7 Posted : 29 May 2022 07:46:01(UTC)
tofulover
Australia
Interesting thanks for that. I will experiment with that.
#8 Posted : 29 May 2022 14:36:55(UTC)
You can have it Class Room style.
Cheers from Up There to Down Under ... Jean.
Polar Circle.sm (6kb) downloaded 13 time(s).
