SMath Studio Forum
Bugs & Problems
Accuracy problem with boolean operator
Joined: 05/10/2016(UTC) Posts: 22   Was thanked: 2 time(s) in 2 post(s)
Dear all, In a cam profile generation program, I perform some boolean operations with angular values (input in degrees). I noticed some boolean operations fail due to a varying accuracy. The file in attachment will clarify what I mean. How can I make these values equal? Reduce the amount of significant numbers? Thanks in advance for any feedback! Kind regards, Jan Accuracy.sm (8kb) downloaded 13 time(s).
Joined: 04/07/2015(UTC) Posts: 6,079  Was thanked: 889 time(s) in 717 post(s)
Originally Posted by: janclaeys  How can I make these values equal ? If numerical arithmetic can't ... You can't. Visit the previous thread in the Forum.
... differently puzzling: set n 49, 50
Joined: 28/08/2014(UTC) Posts: 970  Was thanked: 530 time(s) in 345 post(s)
Originally Posted by: janclaeys  ... How can I make these values equal? Reduce the amount of significant numbers? ... Accuracy.sm (8kb) downloaded 13 time(s). Choose symbolic optimization in the matrix definition.  Best regards. Alvaro. Edited by user 13 May 2022 02:16:47(UTC)
| Reason: Change proposed solution.
on 13/05/2022(UTC), on 13/05/2022(UTC)
Originally Posted by: janclaeys  How can I make these values equal ? Leave the main matrix numeric, explore Numeric/Symbolic in-situ The two Boleans disagree ... IMHO, Numeric is the practical procedure. Cheers ... Jean. Accuracy.sm (15kb) downloaded 3 time(s).
Thanks everybody for the support!
SMath Studio Forum
Bugs & Problems
