I have found a low priority issue where special plots (e.g. text shown on the 2D plot) do not appear on the 2D plot when using an "if...else" domain definition. The Special Plots do show up if I use boolean domain definitions, however. I have attached a sample file here that should make it clear. I also tried submitting this to the bug tracker, but it appears I do not have the privileges to log into the bug tracker system. Thank you! SpecialPlotsBug.sm (9kb) downloaded 17 time(s).
If you declare the system is exact Bolean, set it exact from the onset plot 1
Joined: 23/07/2013(UTC) Posts: 1,124 Was thanked: 506 time(s) in 337 post(s)
Originally Posted by: Mr. Whiskers I have found a low priority issue where special plots (e.g. text shown on the 2D plot) do not appear on the 2D plot when using an "if...else" domain definition. The Special Plots do show up if I use boolean domain definitions, however.
Thank you! You can use cases() in Custom Functions Plugin for that purpose. Plotting, solve(), roots(), FindRoot() and various commands may don't like if/else. Sometimes an error can be fixed by using a line(), not in your example though. Recursive functions doesn't solve when line() and cases() used both, etc etc. These are bitter tricks/bugs, I tend to forgot them everytime. After struggling a while however I remember the "correct usage". Regards
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Would be interesting, why if() is not defined by default as boolean expression just like cases(). Is there any use case, where the original if() is better than the one defined with cases()? If not, then I propose to include re-definition of if() in the custom functions plugin. |
Examine more Bolean applications. Dolphin.sm (38kb) downloaded 5 time(s).
... doctored for convenience. Observe collected plot, easy to manage. Cheers ... Jean. SpecialPlotsBug DOCTORED.sm (11kb) downloaded 6 time(s).
... you make Bolean algo style for convenient command line.
