Offline TIAGO_ENG2012
#1 Posted : 17 February 2022 16:28:08(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
FXsp.sm (503kb) downloaded 10 time(s).
When trying to open the file, the following error appears "object reference not defined for an instance of an object".
Can you tell me how to solve it.
Edited by moderator 18 February 2022 21:37:58(UTC)  | Reason: Marked as bug
#2 Posted : 17 February 2022 16:40:54(UTC)
Was thanked: 974 time(s) in 802 post(s)
File does not open incorrect format
Probably caused by an active AV at time saved.
#3 Posted : 17 February 2022 16:42:57(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
it is possible solver?
#4 Posted : 17 February 2022 16:54:01(UTC)
If it would relate to a solver of some kind it would turn red.
Try to save as instead of just save.
Personally, I always save as ... never simply save.
#5 Posted : 17 February 2022 16:58:10(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
So this scrypt is lost?
#6 Posted : 17 February 2022 17:02:45(UTC)
So this script is lost ?
Maybe yes up to this point ?
Can't help so far !
#7 Posted : 17 February 2022 17:08:25(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
Can't help so far !
thank you very much friend
Offline overlord
#8 Posted : 17 February 2022 18:45:28(UTC)
Turkey
Was thanked: 481 time(s) in 319 post(s)
Can't help so far !
I won't make a promise, but maybe it can be recoverable.
At least and maybe, some parts of it.
Don't fall into Jean's false claims.
Offline overlord
#9 Posted : 17 February 2022 19:03:57(UTC)
Turkey
First attempt to fix the file.
I have removed the force crash section.
Next I am going to correct the crashing section.
I think I can fix very most part of it.
FXsp_r0.sm (474kb) downloaded 6 time(s).
Offline overlord
#10 Posted : 17 February 2022 19:33:20(UTC)
Turkey
Here is your file, completely recovered.
FXsp_r1.sm (604kb) downloaded 12 time(s).
Click to Enlarge
Edited by user 17 February 2022 19:36:52(UTC)  | Reason: Not specified
on 17/02/2022(UTC)
#11 Posted : 17 February 2022 19:39:51(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
Click to Enlarge
thank you very much friend, can you tell me what was done to fix this error?
Offline overlord
#12 Posted : 17 February 2022 20:32:30(UTC)
Turkey
You are welcome.
Culprit is usually an empty \[REGION[####]]\. Yours was at line#1963.
SMath files are sophisticated xml files actually.
You can edit them with a text editor.
The hash inside \[REGION[#####]]\ can differ, but pattern is always same.
\[REGION[#######################]]\
I usually search for this and remove its regions entirely.
If fix works, then try to remove \[REGION[###]]\ individually.
This mostly works to fix the files.
If it doesn't, I remove <region **** </region> sections one by one.
Or multiple of them at same time until file works again.
Then re-add them to pinpoint which region makes crash.
Most important, I always work on file copies to prevent more data loss.
#13 Posted : 17 February 2022 21:22:03(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
You are welcome.
thx u pro
#14 Posted : 17 February 2022 21:23:18(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
You are welcome.
thx u pro -->can you tell me why I can't save this same file in .exe form?
Offline overlord
#15 Posted : 17 February 2022 21:44:20(UTC)
Turkey
I don't know your Windows setup. So can't tell.
I even use linux and I could make an exe file.
Try to Log-in to your account in SMath.
(Login button is Up-Right of SMath window)
This will activate pro mode while saving exe's.
And uncheck compression option.
This is what I did.
This zip file contains exe of your file:
FXsp_r1.exe.gz (1,888kb) downloaded 5 time(s).
#16 Posted : 17 February 2022 22:13:34(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
This is what I did.
I still get the same error as in the topic below
https://en.smath.com/for...ing-to-save-to--exe.aspx
Offline overlord
#17 Posted : 17 February 2022 22:20:20(UTC)
Turkey
Let me try this with a Windows installed computer.
Than maybe I can get what is going on about the issue.
Offline overlord
#18 Posted : 17 February 2022 23:08:08(UTC)
Turkey
I tried your file with a windows 10 installed computer.
It didn't made the executable file on that either.
I have replaced writer plugin regions with embedded text regions.
Now exe file can be created, but not visually as you desired I guess.
And it creates some maple files in document directory when executed.
Actually you don't need maple to solve that kind of functions you used.
Embedded solve() or roots() enough for that, I have replaced it.
So, there is a inconsistency with Linux and Windows versions.
While using Writer Regions and making executable files,
Windows version can't finish while Linux can.
Interesting finding indeed.
FXsp_r2.sm (503kb) downloaded 6 time(s).
#19 Posted : 18 February 2022 00:03:00(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
perfect thank you very much for making your time available, I have been using smart for 4 months and in this learning phase you are one of the best help, thank you very much friend
thanks 1 user thanked TIAGO_ENG2012 for this useful post.
on 18/02/2022(UTC)
