27 Pages«<2223242526>»
Online uni
#461 Posted : 02 January 2022 04:38:50(UTC)
uni
Was thanked: 1285 time(s) in 750 post(s)
SMath Studio compatibility
Plugin updated.
Changes:
- fixed the problem of reaction to the mouse wheel outside the region window;
- returned the green frame that appears during long calculations.
Russia ☭ forever
Viacheslav N. Mezentsev
on 02/01/2022(UTC),  on 03/01/2022(UTC),  on 03/01/2022(UTC)
Offline hanskl
#462 Posted : 10 February 2022 13:46:59(UTC)
hanskl
Norway
Was thanked: 7 time(s) in 5 post(s)
Is it possible to set properties for traces using setprop()?
Best regards,
#463 Posted : 10 February 2022 16:32:14(UTC)
Function(s) ... data set(s) will help.
Offline hanskl
#464 Posted : 10 February 2022 16:41:25(UTC)
hanskl
Norway
Hi Jean,
I'm not following.. can you give an example?
Best regards,
#465 Posted : 10 February 2022 17:47:45(UTC)
Hi Jean,
Often, X_Y plot needs supplementary preparation,
like Joukowsky attached ... Jean.
VectorField StreamLines Joukowsky Airfoil Copy.sm (39kb) downloaded 35 time(s).
Offline hanskl
#466 Posted : 10 February 2022 18:31:15(UTC)
hanskl
Norway
Hi Jean,
Thanks, interesting example, but it does not give me what I desire..
Best regards,
Offline hanskl
#467 Posted : 10 February 2022 22:23:19(UTC)
hanskl
Norway
You mentioned setprop ... What is setprop in Native SS 6179 ?
No problem to plot your function(s) or data set(s).
At this point, you have nothing to plot yet !
You have attached files in the past, today is your day.
setprop is a function that lets you set properties for X-Y Plot from the sheet, like so.
I was wondering if it is possible to set properties in the "Traces" section of the properties-box.
Best regards,
#468 Posted : 10 February 2022 22:55:01(UTC)
Simply, exercise setprop Joukowsky example.
Traces [list] is only: color, size splines/line, symbols ...
In no case it can prepare the plot argument(s).
Sorry, can't help ... Jean.
Offline hanskl
#469 Posted : 10 February 2022 23:36:54(UTC)
hanskl
Norway
In your example, the color of the traces are set by manipulating the order they are plotted in. I could also do that in my case, but I also want to set different line types as well.
This is the fashion I want to set these properties in, if possible.
Best regards,
#470 Posted : 11 February 2022 04:56:04(UTC)
line types colors ... belong to the X_Y Plugin.
Even if you could do some, in many pages long,
then you would dream of a drop down menu as actual.
One you will not do is line spline ... immensely useful.
2D Isometric Copy.sm (57kb) downloaded 25 time(s).
Offline churichuro
#471 Posted : 11 February 2022 05:03:26(UTC)
churichuro
Mexico
Was thanked: 27 time(s) in 22 post(s)
check this post --> DISLIN plugin
Offline hanskl
#472 Posted : 11 February 2022 12:06:08(UTC)
hanskl
Norway
Thanks, I will look into that plugin.
Online uni
#473 Posted : 11 February 2022 13:27:11(UTC)
uni
No, now it is not possible. I've written code for this, but haven't tested it yet. It's a little more difficult.
Russia ☭ forever
Offline hanskl
#474 Posted : 11 February 2022 15:46:42(UTC)
hanskl
Norway
Thanks for the clarification. Are you planning to implement it?
Online uni
#475 Posted : 11 February 2022 18:33:43(UTC)
uni
There is another method by which you can get the same result. But it still exists as an idea. The implementation of the setprop() function uses a technique that I would not recommend for use. A new idea requires a redesign of the storage format and appearance, which I don't have time for.
I already wrote that we have few resources to maintain the code well. At the moment I'm doing cosmetic changes and simple improvements in the existing code.
Sometimes I need a little inspiration to make a significant revision. Now I can't promise to expand the functionality.
Russia ☭ forever
on 11/02/2022(UTC),  on 11/02/2022(UTC),  on 27/11/2022(UTC)
#476 Posted : 12 February 2022 15:02:09(UTC)
Eventually, you may not know what will plot, what will NOT plot.
For instance, erf(x) is not scalar in Smath and capricious.
Per say, NON-linear integration rejects erf(x) as the NON-linear path.
Offline overlord
#477 Posted : 13 February 2022 17:54:28(UTC)
Turkey
Was thanked: 526 time(s) in 352 post(s)
Not related with quoted question.
Offline hanskl
#478 Posted : 14 February 2022 10:52:43(UTC)
hanskl
Norway
Well I hope you some day find the time and inspiration to do so. SMath is great, but it is even better with all the useful plugins you and others develop and support.
Best regards,
Online uni
#479 Posted : 23 June 2022 21:37:44(UTC)
uni
Plugin updated.
Changes:
- added support for primitives: "-" and "|";
- minor cosmetic fixes.
Russia ☭ forever
on 23/06/2022(UTC),  on 23/06/2022(UTC),  on 24/06/2022(UTC)
Online uni
#480 Posted : 26 June 2022 12:37:07(UTC)
uni
If you sometimes see a similar problem, then this is an error in the operation of a parallel algorithm used to speed up data processing. My implementation is not done very carefully, so for now I have to observe this behavior. The hardest part about implementing plugins is taking into account a lot of implicit little details.
Russia ☭ forever
on 26/06/2022(UTC)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
