Offline Razonar
#1 Posted : 02 February 2022 04:49:54(UTC)
Razonar
Uruguay
Was thanked: 796 time(s) in 504 post(s)
Text regions appear with a black background when the file is saved as an HTML page. SMath Version 0.99.7921.69
SMath screen capture
HTML output page screen capture
on 03/02/2022(UTC)
Online Jean Giraud
#2 Posted : 02 February 2022 15:18:19(UTC)
Was thanked: 974 time(s) in 802 post(s)
Similar bug including all work sheet regions was reported,
from recollection: not attended ... still existing once in a while.
#3 Posted : 03 February 2022 01:20:58(UTC)
Was thanked: 1318 time(s) in 869 post(s)
Thank you, bug confirmed and fix tested and committed to the repository.
Worksheets with unwanted black background still exists because is a property saved in the affected files, but those are a marginal number and the bug on saving is fixed in recent versions of SMath Studio.
Since black is a valid background color there aren't robust ways to improve the loading of affected files directly on program side (and anything would add a small time penalty on loading for each region in each file, all for a once in a bluemoon case, very noticeable and easily fixable from user-side that single time it happens).
To fix those existing worksheets you can either:
1. open the file, select the black regions and change the background color to transparent;
2. use a batch fix method like those proposed here: https://en.smath.com/forum/yaf_postsm75355_Black-regions.aspx#post75355
Edited by user 04 February 2022 16:46:27(UTC)  | Reason: Not specified
on 03/02/2022(UTC),  on 03/02/2022(UTC)
