#1 Posted : 28 January 2022 02:37:35(UTC)
If the object does not exist in the scan ... I understand.
If > 10^307 ... if < 10^-307 ... I understand.
What else creates "on error" ?
MCD 11 and Smath often disagree.
In some instance, Smath "on error" must be coded otherwise.
Comments appreciated .... Cheers, Jean.
#2 Posted : 28 January 2022 15:53:00(UTC)
Hello Jean,
try/onerror is just a way to manage errors.
They happens because a lot of reasons (values too high, file I/O, operation on strings, mixed types on data sources, mixed units, bad user input, etc...) and you might expect some specific errors or some "possible, currently undefined" errors.
If you might want to handle them in a custom way other than the low-level error message, that is the function to do it.
For example you can use it to override results with some default value, or give some hint to change something; the use depends on the context, what are the input variables and what you expect to happen in case of a predictable or "unpredictable" error.
IDK if can be improved in some way, but is a common and very simple function in most programming languages (try-catch in C-style languages, try-except in Phyton, ...)
Edited by user 28 January 2022 16:03:35(UTC)  | Reason: Not specified
#3 Posted : 28 January 2022 18:11:21(UTC)
Thanks Davide, you are great Educator !
Take care ... Jean.
Similar Topics
ODE "on error" (Samples)
by Jean Giraud 05/12/2020 20:54:52(UTC)
"on error" test image rotate (Feature Requests)
by Jean Giraud 16/04/2016 20:42:32(UTC)
