Hi, Im trying convert this mathcad solver to smath but it doesnt work. Radius_318a.sm (10kb) downloaded 8 time(s).
Joined: 23/12/2011(UTC) Posts: 296   Location: italy Was thanked: 103 time(s) in 87 post(s)
It is a non-linear system. With the internal "Roots" solver it is appropriate to use initial values ​​sufficiently close to the result. You can use some of the smath plugins that are more robust. For example, with "Solve" of the "Maxima plugin you get the result.
Radius_318a_ser.sm (338kb) downloaded 28 time(s).sergio
Joined: 23/07/2013(UTC) Posts: 774  Was thanked: 276 time(s) in 196 post(s)
With an addition to sergio's solution; You can use vectors while solving. Regards
Solution with another solver. Regards al_nleqsolve.sm (7kb) downloaded 13 time(s).
wow, thanks a lot guys.
//Edit: the thanks button is not working. I cant give you thanks
