Hi, Im trying convert this mathcad solver to smath but it doesnt work. Radius_318a.sm (10kb) downloaded 10 time(s).
It is a non-linear system. With the internal "Roots" solver it is appropriate to use initial values ​​sufficiently close to the result. You can use some of the smath plugins that are more robust. For example, with "Solve" of the "Maxima plugin you get the result.
Radius_318a_ser.sm (338kb) downloaded 32 time(s).sergio
With an addition to sergio's solution; You can use vectors while solving. Regards
Solution with another solver. Regards al_nleqsolve.sm (7kb) downloaded 23 time(s).
wow, thanks a lot guys.
//Edit: the thanks button is not working. I cant give you thanks
